Old 01-20-2024, 05:14 PM   #1
IMCWORTH
IMCWORTH's Avatar
Drives: 2023 Camaro Convertible ZL1 A10
Relay K2 say's Run / Crank
Some of these conversations
any help would be appreciated
IMCWORTH is offline   Reply With Quote
Old 01-20-2024, 11:25 PM   #2
Jaeblvck
Drives: Chevy Camaro SS
I'm having the same issue, I can't find anything on it
Jaeblvck is offline   Reply With Quote
Old 01-21-2024, 11:16 AM   #3
JSH
JSH's Avatar
Drives: '20 ZLE
Take a look at this layout https://fuse-box.info/chevrolet/chev...ses-and-relays
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 01-21-2024, 05:21 PM   #4
IMCWORTH
IMCWORTH's Avatar
I did see this already
Old 01-21-2024, 05:26 PM   #5
JSH
JSH's Avatar
Drives: '20 ZLE
Originally Posted by IMCWORTH View Post
I did see this already No help.
The fuse box in the trunk has NO K2 relay
which should be a fuel module relay
(even if it was there not sure if that relay could be used for an immobilizer relay replacement)
I'm looking at F55 in the engine compartment
2020 ZL1LE A10.
Old 01-21-2024, 05:37 PM   #6
IMCWORTH
IMCWORTH's Avatar
That is a 5 amp fuse.
Old 01-21-2024, 06:14 PM   #7
Jaeblvck
what about F50 fuel system control module ignition
Old 01-21-2024, 06:15 PM   #8
IMCWORTH
IMCWORTH's Avatar
That again is a fuse. Need a relay
Old 01-22-2024, 10:50 AM   #9
IMCWORTH
IMCWORTH's Avatar
Originally Posted by The Maverick View Post
K10, starter relay in the fuse box under the hood, seems to work fine with an A10 sixth gen. Gives a "no crank" symptom -- but the start button still turns on the ignition.
Old 01-23-2024, 09:49 PM   #10
Jaeblvck
hey so after extensive searching, K8 is your fuel pump relay. I unplugged it to check and it checks out car will not start. it'll say fuel prime relay on the fuse box diagram.
Old 01-24-2024, 11:54 AM   #11
mbnwa
Drives: 18 NGM ZL1 1LE
As far as I know, the remote does not act as an on/off switch. After the relay is armed and the car is running, you are not able to disconnect the relay by hitting the remote again.
I would reach out to them and have a conversation to confirm the intended use case.
PRIOR CAR:
17' Camaro 2SS A8 Vert Upgrades: Pray MSD IM/95mm TB/E85/Tune / Roto-fab CAI / GM Dark Taillights / LED Turn's with VLED Resisters / LED Reverse Lights / JWM Side Markers / Factory UQT PDR (CTS-V) / BMR DSL, MM010 / TSP 1 7/8 / Front Camera / Eyebrow Harness / Elite Engineering E2-X / AEM Wideband with Aeroforce single pod / HD Radio / OnStar Delete / RPM Roll Bar
mbnwa is offline   Reply With Quote
Old 01-24-2024, 12:56 PM   #12
IMCWORTH
IMCWORTH's Avatar
Originally Posted by mbnwa View Post
As far as I know, the remote does not act as an on/off swidisconnect the relay by hitting the remote again.
Old 01-24-2024, 04:35 PM   #13
mbnwa
@IMCWORTH check your PM's
PRIOR CAR:
Old 05-01-2025, 07:08 AM   #14
Roddrz
Roddrz's Avatar
Drives: 2022 Camaro V6 2LT Convertible
In the engine compartment fuse block, would anyone know the function of the K2 Relay Run/Crank and the K10 Relay Starter?
Assuming K10 disables the starter motor, what is K2's function?
Thanks in advance, while I investigate.
Roddrz is offline   Reply With Quote
