![]() Drives: 2016 z06 Join Date: Sep 2020
alignment warranty
so my 2023 zl1 purchased this August has 900 miles and the local dealer refused to check and set my alignment under warranty. So my question is under the first year and under 7500 miles is it under warranty to get the alignment? I showed the dealer
Factory Alignment Warranty - CAMARO6. PSA - GM only covers the factory alignment on these cars up to 7,500 miles. To no avail and left with my 500 mile oil change and no alignment done. |
![]() Drives: 997 GTS, ZL1 A10, ZLEM6, ZLEA10 Join Date: Dec 2017
Alignment is covered if there is a problem not just because you want one. I believe it’s minimum of 750 miles and within 1yr. I don’t recall the max mileage but there is one.they have to call it in and get special approval in the system.
#3 | |
Lover of Speed
Drives: 2018 ZLE Join Date: Feb 2016
Killer Whale Racing
2021 One Lap of America Track Videos 2019 One Lap of America Track Videos 2017 One Lap of America Track Videos 2022 Ram TRX 2018 Camaro ZL1 1LE 2020 Range Rover Sport SVR (Sold) 2014 Grand Cherokee SRT (Sold) 2014 Camaro Z/28 (Sold) |
a alignment is a funny area because by the time you notice your tires are worn out and then find out your alignment is off you are out a set of tires. Thanks for the info and will be taking it in with a problem.
#5 | |
![]() ![]() ![]() ![]() Drives: 2018 Camaro ZL1 Join Date: Aug 2018
For them to do it, they have to replace certain bolts that are technically 1 time use and most dealers don't have them in stock. |
The top of the rear tires are canted inward and the car drifts it is a constant correction with no wind-if they have to replace bolts-shims etc it would be for a correction in the alignment.
#7 | |
![]() ![]() Drives: 2017 Camaro SS, 2011 Corvette GS Join Date: Feb 2019
If they still won't do it, find another stealership that will honor the warranty and do the work. You are under zero obligation to keep going to the stealership you bought the car at. |
#8 |
![]() Drives: 1977 Pontiac Trans Am Join Date: Oct 2019
Not trying to be a smart ass but have you driven cars with wide tires before? I live in Florida as well and the ruts in the road tend to move the car around a bit will driving, the camaro does not tram as bad as the mustang but it still does it a bit.
#9 | |
Coupe Newbie
Drives: '23 CT5-V BW, '21 Corvette HTC Join Date: Jul 2011
Most dealers I know of can do a quick alignment check right where you drop off your car off for service. If your ZL1 is within specs then what you're expericencing is trammeling from the wide tires. Just make sure the dealer uses the specs for the FE4 suspension in the ZL1.
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
#11 |
Most shops will put it on the rack and check it at no cost. In my area, anyway. Back before that it was $40 to check it and $40 more to align if needed. This is a pretty simple thing to get done, surprising that they wouldn't even check it.
#12 | |
#13 |
Good alignment will minimize tramlining even with wide tires.
I'm running 305s in the rear (earlier I also had 315s for a season or two), 285s in the front, and the car hardly wanders even on roads with significant crowns. One can let go of the steering wheel for an eighth or even a quarter mile and the car will still track straight before it follows the crown.
#14 |
![]() Drives: 22 ZL1 23 1SS Redline Join Date: May 2022
My dealer does free alignment checks and mine was adjusted under warranty. I didn’t even buy the car from them - had to go out of state to purchase. Didn’t know my alignment was off they check it for everyone.
