Exia
Drives: '16 Z06 C7.R Edition, '18 2SS Join Date: Mar 2017
OEM LT 18s on SS 1LE
I just picked up a '22 SS 1LE and I'm looking to get a second set of wheels and tires for winter.
I was thinking of ordering the OEM LS/LT Camaro 18 inch wheels and putting the same sized winter rubber on them. Will these clear the brakes and not rub? I've seen a few threads on 18s and some people say they clear and others say they added spacers. The wheels are 18x8.5 with a 32 offset and tires are 245/50/R18 |
![]() ![]() Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
I don't have an exact answer for you as that is an odd size. It should clear the brakes (all 18" wheels that I know of do), the offset will let you know if you need spacers to clear the struts. Perhaps with ET32 you may need spacers at the front. I need a 26mm spacer for ET35(18x11) at the front.
If I had to guess with only 8.5 inch width and ET32 you should not need a spacer. Generally with 18"x10" or larger wheels you do have to grind down the knuckle on the strut to make the wheel clear. Use this page as a guide, they offer some guidance depending on your offset/wheel size. https://apexwheels.com/fitment-guide...-fitment-guide |
#3 | ||
2020 Shadow Gray 2SS
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF-Full Front & Rockers, 35% Tint, CeramicPro coated, RST Stainless Brake Lines, Castrol SRF, MSD Plug Wires, Mamo V3 Ported TB Left: My "fun" ride (455 HP). Right: My "work" ride (52,000 HP): a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph. BOTH AWESOME to operate... |
Exia
Hmm, I'm not sure on the copper free. Its a 2022 and I know the copper free was offered for California I believe? I would think as a Canadian car and the model year it probably is not copper free.
Post a picture of your front Calipers & Rotors and we should be able to tell you.
#7 |
Exia
Here are pics of the front caliper and rotor.
#8 |
Those look like standard (non-Copper Free) 1LE fronts, you should be good with 18" wheels...
#9 |
Exia
Thanks Bud, I'll be getting a set put on later this week so hoping its fine. Its getting colder here but these Supercar 3R tires are holding up so far.
