Old 12-07-2023, 03:03 PM   #1
FactoryMatt
FactoryMatt's Avatar
Drives: '22 2SS 1LE
rear cradle alignment tool/pins--needed?
anyone know the diameter of these pins? want to duplicate using another material, as they're hard to find. BMR says theyre not really needed when doing the delrin bushings, but idk..seems there's been some post-install alignment issues on here.
otherwise, anyone have a set they'd want to sell?
thanks again!
Kent Moore CH-51034
https://www.ebay.com/itm/266486318583
FactoryMatt is offline   Reply With Quote
Old 12-07-2023, 07:55 PM   #2
SCCAForums
SCCAForums's Avatar
Drives: Chevrolet Camaro, Ford Mustang
Not needed in my experience.
2022 SS 1LE - Vivid Orange - SCCA CAM-C & Optima Ultimate Street Car GT
Katech, MSD, QA1, Hurst, Anderson Composites, ProParts USA Custom Suspension, Auto Addict USA, Forgeline Wheels, G-Loc Brakes, Nine Lives Racing, MTX Audio, Penske Rapid Repair, RacingBrake
SCCAForums is offline   Reply With Quote
Old 12-12-2023, 01:47 PM   #3
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
You can shine a light into the alignment holes and line them up. A bit fiddly, but very doable.
Old 12-12-2023, 08:11 PM   #4
Dabjbr
Dabjbr's Avatar
Drives: 2020 SS 1LE
I literally used wooden dowels from Home Depot. But they aren’t truly necessary.
Dabjbr is offline   Reply With Quote
Old 12-12-2023, 08:12 PM   #5
FactoryMatt
Drives: '22 2SS 1LE
Do you remember the diameter? How tight/precise was the clearance with them?
Old 12-12-2023, 08:15 PM   #6
Dabjbr
Dabjbr's Avatar
Drives: 2020 SS 1LE
I now remember getting them from Lowe’s. Cheap little pack like this… I don’t remember the size but I do remember buying several various sizes and then returning what I didn’t need.
https://www.lowes.com/pd/Madison-Mil...dia/1000217163
Oh, and I remember them working exactly as needed. Snug enough to fit but still able to pull back out.
*Ps, I’m in Roseville and track at Thunderhill, Sonoma and Laguna Seca.
Old 12-13-2023, 03:11 PM   #7
FactoryMatt
Drives: '22 2SS 1LE
Thanks, maybe i'll give that a try. Nice! PM'd you.
Old 12-02-2025, 01:00 PM   #8
zebbra
Drives: Camaro
Hi, I found your old thread where you were looking for the alignment pins for the rear subframe.
I’m trying to do the same procedure now, and I wanted to ask you two things:
1. Did you manage to solve the problem in the end?
2. Could you please tell me the exact dimensions (diameter and length) of the alignment pins you used?
Any help would be greatly appreciated. Thank you!
zebbra is offline   Reply With Quote
Old 12-02-2025, 06:09 PM   #9
FactoryMatt
Drives: '22 2SS 1LE
i bought them new from an obscure vendor or from ebay cant remember. cant find the order. they worked great, according to the shop that i had do the work. i can get you the dimensions shortly.
i can also rent them to you if you'll cover shipping and a deposit.
let me know what you want to do.
edit: i think you're in europe?'
total length including knurled handle: 350mm
operative length of alignment shaft: 250mm including a 5mm chamfered dull point
diameter: 20mm
part number: CH-51034-1
https://www.freedomracing.com/ch-510...TU4pCOgzz1PKfr
https://www.acurapartsforless.com/oe...SAK1TK50YNEJJC
https://www.ebay.com/itm/23633279851...AAAeSwdeZoyx41
Old 12-04-2025, 09:30 AM   #10
zebbra
Drives: Camaro
Thank you very much for the dimensions, I really appreciate it.
Unfortunately I’m in Europe, so the shipping and customs would be quite expensive for me. I’ll try to find the CH-51034-1 alignment pins somewhere here in the EU, or have a local machine shop make them based on the measurements you provided.
Thanks again for your help!
Old 12-04-2025, 10:02 AM   #11
ZL1_1LE
Drives: Camaro ZL1
Are you changing the rear cradle bushings? Not really a need for the alignment pins if done properly. I did mine in my garage and had no issues re aligning the cradle. Just be patient and follow the directions, you'll be good.
ZL1_1LE is offline   Reply With Quote
Old 12-04-2025, 05:15 PM   #12
Dabjbr
Dabjbr's Avatar
Drives: 2020 SS 1LE
You can use wood dowels to help. Even simpler, use a white paint pen and make a bunch of witness marks where the subframe meets the chassis. Replace bushings and then make the subframe line up again with your paint marks. You'll realize that's all that's needed.
You'll understand once you get under the car. And if you're a tiny bit off, you can simply get your car aligned.
Old 12-04-2025, 07:21 PM   #13
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
Yea the very small amount of slack is easily adjusted out in the alignment. Its a subframe not a rolex so don't overthink it.
bishopts is online now   Reply With Quote
Old 12-05-2025, 12:23 PM   #14
DeuceCam
Drives: LT1
Good info.
I didn't do enough homework. Didn't realize there was a GM provision for aligning the rear subframe. Now I'm left to wonder if the shop that installed my lockout kit aligned the subframe properly
DeuceCam is offline   Reply With Quote
