Old 11-15-2023, 02:37 PM   #1
ZeroC
ZeroC's Avatar
Drives: 18 2SS LT4 Top
Fuse Box Lugs Diagram wanted
does any have a the info on what the larger lugs are on the left side of the fuse block - most diagrams dont even show em :(
ZeroC is offline   Reply With Quote
Old 11-15-2023, 04:04 PM   #2
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
can you post a picture of what you are talking about?
Old 11-15-2023, 07:30 PM   #3
The fuse block hosts a couple of large relays, too, but they are listed in the owner's manual, so you probably mean something else...
Old 11-15-2023, 08:19 PM   #4
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
If you’re talking about all the lugs on the back end of the box, all the heavy gauge red and black go to the most important things to make your car function day in and day out and the rest go to less important things. If what you’re asking is can you piggyback them, yes you can. If it is not a crazy constant amperage.
Old 11-15-2023, 09:34 PM   #5
ZeroC
ZeroC's Avatar
These ones just curious what is what gotta be a wire schematic somewhere
Old 11-16-2023, 12:32 PM   #6
ctrlz
Might help:
https://www.camaro6.com/forums/showthread.php?t=558328
Old 11-16-2023, 01:39 PM   #7
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
After a brief look through a couple manuals, that under-hood 6-post 200-100-100-80-200 amp fuse block is called X50B (not to be confused with the fuse box X50A that it's attached to). There appear to be many Camaro variants between what my manuals show and what is shown in the pictures in the thread linked above to be able to say what those 6 posts are for your car. So if I were to post a diagram, there's a fair chance it would be wrong for your car.
Your best bet may be dropping the $22 for the 3 day GM service manual access so you can get what you need for your VIN: https://www.acdelcotds.com/subscriptions#
Old 11-16-2023, 02:11 PM   #8
ctrlz
There appear to be many Camaro variants between what my manuals show and what is shown in the pictures in the thread linked above to be able to say what those 6 posts are for on your car.
Agree. The x50b fuse block is used in multiple GM models and product lines.
Maybe someone with an identically optioned camaro could post a picture. otherwise, pray you can find it in GM tech literature.
Old 11-17-2023, 07:27 PM   #9
ZeroC
ZeroC's Avatar
Originally Posted by ctrlz View Post
this helped for sure thanks man ! good find
