Old 11-06-2023, 08:18 AM   #1
Dadzl1
Dadzl1's Avatar
Drives: Zl1
Will it fit ?
Shopping for tires on my 2018 zl1. No one rides in the rear ( not that any adult would fit ) . Anyone know the limits ? Looking at this , BFGoodrich G-Force Comp-2 A/S Plus All-Season Radial Car Tire for Ultra-High Performance, 305/35ZR20 104Y. I don’t use it in the rain or slow. But I’d like to drive it a little longer ( 40-50s ) . Before the snow and salt arrive . Also 285/35 zr20 on the front .thanks in advance .
Dadzl1 is offline   Reply With Quote
Old 11-06-2023, 09:16 AM   #2
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
At almost 28.5” not without rubbing I’m guessing
Old 11-06-2023, 10:10 AM   #3
Vigilante375
Drives: 2018 Camaro ZL1
Should be fine in the front and rear but since you have a 2018. You should relocate the wiring harness located in the driver left rear wheel well.
Old 11-06-2023, 05:18 PM   #4
Yes, it will fit, this is what I'm running as a compromise, although with Michelin PS4S tires.
Two things, first, as Vigilante375 mentioned, make sure you relocate the driver side body wiring harness (see how-to here); second, the fronts may rub the wheel well liner every so slightly at full lock, so expect some wear, particularly on the driver side. This taller wheel/tire combination doesn't exactly help real world performance either.
In other words, while this setup works (and looks pretty nice if I may say so, see my avatar picture), it isn't recommended. My next tire purchase will be a different, shorter sized combo.
Old 11-08-2023, 07:35 AM   #5
SteveV
SteveV's Avatar
Drives: 2018 ZL1 Camaro 6M Red Hot
I have a 2018 and I am running the Nitto RIII 305/35 20 in the rear and they don't rub.
Yes, I have pulled both rears to look for rubbing and possibly relocate the harness. Was not necessary, does NOT rub.
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
SteveV is offline   Reply With Quote
Old 11-08-2023, 07:36 AM   #6
SteveV
SteveV's Avatar
Here is how they look...
Old 11-08-2023, 08:24 AM   #7
ZPirate
ZPirate's Avatar
I would recommend a set of rock guards with those tires. I have ACS Composite rock guards on both my 1LE and my ZL1.
2003 Nissan 350Z (modified)
2009 BMW 135i (Sold)
Old 11-08-2023, 08:59 AM   #8
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Yep, either PPF up to the respective body lines or rock guards. The ACS guards are good looking too.
Old 11-08-2023, 09:49 AM   #9
Dadzl1
Dadzl1's Avatar
Drives: Zl1
Thanks for all the pics and great info
