Old 11-04-2023, 04:57 AM   #1
ukester
Drives: 2016 z06
copper free brakes?
so on my 23 to get rid of a lot of brake dust is there a lot to change over to copper free brakes? I had changed brake pads to get rid of brake dust on my 16 Z06 and it did get rid of the dust it also changed the distance to stop the car.
TIA
Mark
ukester is offline   Reply With Quote
Old 11-04-2023, 07:34 AM   #2
Vigilante375
Drives: 2018 Camaro ZL1
You want to change to copper free brakes to get rid of brake dust? Is that what you're saying?
If so, then that's not going to happen. Copper free brakes still produce the exact same amount of brake dust. Plus to change to the copper free brakes that come as an option now, you'll need to change the rotors, calipers and pads. Because they are slightly bigger to offset the more efficient heat dissipation that the copper brake offer.
You'll need to go with another set of pads like power stops or whatever else is out there. I've only used the stock pads since I don't mind the brake buildup and race the car from time to time.
You will sacrifice braking performance by going to another pad.
Old 11-04-2023, 08:51 AM   #3
If you don't want brake dust and are willing to sacrifice some performance, look into PowerStop Z26 pads. Lots of mentions in the forums, and available on the cheap at many performance parts sites.
Old 11-05-2023, 04:12 AM   #4
ukester
Drives: 2016 z06
thanks for the replies will keep the brakes they way they are.
Old 11-08-2023, 07:41 AM   #5
SlowWhite
Drives: ‘17 ZL1
If I want to switch to ceramic pads (prefer Akebono) as I might start to daily the ZL1 I’m not sure the part number provided on their website (ASP1001) is actually the correct front pad. I have the copper free brakes.
Since my brakes are slightly larger can anyone confirm if these Akebonos will fit the front? If not, can anyone recommend ceramic pads for my car?
I assume the rear doesn’t matter copper free or not but feel free to correct me if I’m wrong.
SlowWhite is offline   Reply With Quote
Old 11-08-2023, 09:30 AM   #6
Vigilante375
I believe the rears are the same size (rotor, caliper and pad) for the copper free and non copper free.
I cannot speak for the other question about the fitment for the Akebono fronts. Might need to call them and confirm.
Old 11-08-2023, 12:17 PM   #7
split_bumper
Drives: 24 ZL1, 6.2L Denali, 73 SplitBumper
I also have BCD option on my car. From what I have gathered, the rears are the same. The fronts are slightly different, running a non copper free pad will result in a cold ring towards the inside of the rotor face. Either pad will work, its just whether that cold ring of 3mm will add increased stress or not to the rotor.
I am sure being that all the collectors editions have BCD, some aftermarket will come out with a replacement that is specific to these copper free pads. I will find the forum thread discussing the pad difference and add it to my comment.
Post#11, 14, 16 in this thread
2024 ZL1 Radiant Red / Coupe / M6 / PDR / BCD / Carbon Scoop, Dash, Shifter / Red Seat Belts / Black Lugs
https://cws.gm.com/vs-cws/vehshop/v2...FJ1R60R0111531
split_bumper is offline   Reply With Quote
Old 11-08-2023, 03:51 PM   #8
MT-SS1LE
Drives: 2023 SS 1LE Sharkskin
Copper free brakes, isn't that another idiotic California requirement? Personally, I could care less about brake dust, my car gets washed weekly. I want the best performing brake pads and will deal with dust.
ΜΟΛΩΝ ΛΑΒΕ
MT-SS1LE is offline   Reply With Quote
Old 11-08-2023, 04:05 PM   #9
Vigilante375
CA and WA requirement. It's the same pad just shaped different and no copper in the brake pad itself. Still puts out the same amount of brake dust and supposedly brakes the same.
Old 11-08-2023, 04:23 PM   #10
jbp8653
jbp8653's Avatar
Drives: 2017 ZL1,2013 ZR1, 1952 C3100 Resto
I put the power stops on my 2017 right after I bought it new back then. I don't track the car. It stops just fine!!!! NO DUST!!! LOL
2017 ZL1,Mosaic Black, auto,nav/pdr, Roto Fab,Mamo
2013 ZR1 60th Anniv.
1952 C3100 resto-rod. LS6, 4L60e, 228R cam
jbp8653 is offline   Reply With Quote
Old 11-08-2023, 07:02 PM   #11
SlowWhite
Drives: ‘17 ZL1
Correct, I think Oregon as well. I called Akebono and they had no idea about the copper free brakes and just said it’s the same pad. Didn’t instill a lot of confidence.
Old 11-09-2023, 12:21 PM   #12
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
It's been said that brake dust is largely rotor material, not pad material.
I can't attest to that, but I can say that while my ZL1 (non-California spec) brakes made a whole lot of dust for the initial 1000 miles or so, the production of dust from street driving has greatly diminished since.
Old 11-09-2023, 01:19 PM   #13
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
BCD option includes the largest production front caliper offered on the 6th gen (bigger than ZL1/1LE) by a little.
You get the ZL1/1LE rear caliper size as well. Overall I consider it an upgrade just in size of caliper and rotors. You can always change out the copper-free pads with something else.
https://www.camaro6.com/forums/showthread.php?t=614204
2016 1LT v6
- Totaled
Happiness: Infinite
Old 11-09-2023, 04:06 PM   #14
LateBrakeU2
Drives: 15 RH Z/28, 23LT1VOM
My 23LT1 has the same 4 pot calipers from the SS, but got the C8Z51 rotors and pads for no extra charge because it's a CA delivered car!
LateBrakeU2 is offline   Reply With Quote
