Old 05-26-2022, 10:45 AM   #1
BusDriver20
Drives: ‘16 Ford Focus ST
Copper-Free ZLE
After searching through Camaro6 I just updated my ZLE order to include the BCD code “Copper-Free performance brake system ZL1”. Originally I thought it was just a revised pad compound but I understand it’s larger front rotors and calipers as well. (Blackwing bits possibly?). I’m still unsure if it’s a waste of $500 but there seems to be some future benefit.
23 ZL1 1LE
1100 Status 05/07/22
BusDriver20 is offline   Reply With Quote
Old 05-26-2022, 10:55 AM   #2
jkerb720
Drives: 2013 zl1 camaro
I had read that all they changed was the pad material to adhere to California and Washington's laws. I cant imagine them redesigning the caliper and rotors to adhere to a material change.
jkerb720 is offline   Reply With Quote
Old 05-26-2022, 11:30 AM   #3
BusDriver20
It seems on the ZL1’s the rear setup is just a pad change but the front is a larger caliper and rotor from the Caddy parts bin to offset the lack of heat dissipation from the loss of copper. I still haven’t found any performance comparison between the stock setup and copper free. Bigger deal on the SS’s but not sure about the ZL1’s.
23 ZL1 1LE
Old 05-26-2022, 01:06 PM   #4
Vigilante375
Drives: 2018 Camaro ZL1
I'm pretty sure the ZL1 and 1LE package have the exact same brake system. Pads were just changed to non copper ones die to liberal California and Washington, as stated before.
Old 05-26-2022, 01:10 PM   #5
Jofu
Drives: 2022 Wild Cherry ZL1 1LE
The discs and calipers are indeed bigger in the front, when selecting the BCD option versus without, on any ZL1s (1LE or otherwise).
Geoff
Jofu is offline   Reply With Quote
Old 05-26-2022, 01:18 PM   #6
AZ_1LE
Drives: 2019 ZL1 1LE
As long as you're not registering it in CA or WA, you don't need that "option."
Old: 2017 SS 1LE
Old: 2017 ZL1
Current: 2019 ZL1 1LE
AZ_1LE is offline   Reply With Quote
Old 05-26-2022, 01:25 PM   #7
BusDriver20
That’s where it’s getting confusing. Some other threads seem to point to different GM part numbers for the front rotors and calipers on the copper free. On the zl1 it’s a 398mm rotor compared to a 390mm
https://www.camaro6.com/forums/showt...php?p=11128284
23 ZL1 1LE
Old 05-26-2022, 02:35 PM   #8
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
Looks like it's the new non-CC option brakes developed for the CT5-V BW, both the non-CC and CC use copper free pads only on the CT5-V BW. Presumably for the entire country not just WA and CA, so they're reusing these brakes to keep SS and ZL1 legal in 50 states.
SFV1LE is offline   Reply With Quote
Old 05-26-2022, 02:41 PM   #9
AZ_1LE
Oh crap, I had no idea. Must be that they wanted slightly larger rotors to get the same braking performance due to the less-grippy copper pads?
Old: 2017 SS 1LE
Old: 2017 ZL1
Old 05-26-2022, 03:09 PM   #10
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
I'm betting that's exactly what happened. Needed bigger components to compensate for the lower copper-free brake output.
IMO, getting this package is 100% worth it. The pads for the 390mm setup will still fit on the fronts but leave a few mm of unused rotor surface on the ID, meaning there's lots of higher-output pads that can be bought off the shelf that fit as long as you don't go back to OE pad shape for the life of the rotor. Going forward, I'd wager aftermarket companies will pick them up and start offering higher output pads in the larger size, in which case you get even more brake capability than the 390 setup can get with aftermarket pads.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 05-26-2022, 04:34 PM   #11
cdb95z28
cdb95z28's Avatar
Here's the front OE ZL1 Ferodo HP1000 pad (171-1192/23399101)compared to the OE BCD Copper Free Brembo BRM0023 pad (85158659). The backing plates are similar but not the same. The material shape is quite different. But the BCD material shape transitions to a shape similar to the Ferodo shape when the pads are almost worn out. The Ferodo HP 1000 still fits in the new BCD caliper but there is a small area near the hat that will not be used compared to the BCD pad.
The friction code on the Ferodo HP 1000 is "FF" and the BCD Brembo is "GG".
On Rockauto, the copper free front pads ($281) are more expensive than the Ferodo HP1000 ($235).
Copper Free at bottom of both pictures
"KEEP THE FAITH"-Fbodfather
Old 05-26-2022, 06:06 PM   #12
BusDriver20
Attachment 1100207
Attachment 1100208
Thanks for that side to side post and the clarification. The order is in and I feel better about it. Now, like everyone else, there is just the wait for the General to pick it up.
23 ZL1 1LE
Old 06-20-2022, 11:58 PM   #13
MatthewAMEL
MatthewAMEL's Avatar
cdb95z28, thanks for posting that pic. Nice to see they increased the mu on the BCD pad.
Has anyone reached out to Hawk or Carbotech or any of the others to see if a pad is coming for that caliper? I would imagine it's gonna be a low-volume part since it's only on a few Camaros and all Blackwings.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
2025 Hysteria Purple
C8 Z07
Old 06-21-2022, 07:23 PM   #14
cdb95z28
cdb95z28's Avatar
Word is that the front pad shape is 8091 which is shared by many GM and other manufacturer CCM optioned cars. I have found some sites that offer a Pagid RSL1 in the 8091. Essex has a "non CCM" DS 1.11 replacement for the Gen5 Z/28 but the part # is the same as what is offered on the Gen6 ZL1/E. Using the HP1000 ZL1 pad shape results in a cold ring on the rotor vs the BCD pad. The pad shape differences between the BCD and the HP1000 ZL1 pad are subtle but that resulting cold ring may or may not be an issue. On the SS 1LE, the rears are essentially the ZL1 brakes, so that's an easy find.
https://www.paragon-products.com/Pag...91-p/u8091.htm
https://www.northstarmotorsports.com...productID/8219
https://www.pagidracing.com/en/produ...hape-8091.html
The BCD front pad (8091) has just a bit more radial depth. This equates to a difference of about 3.6mm at the rotor face (see attached pics). The orange reference is the BCD pad sweep edge and the green is the HP1000 sweep edge.
