Old 10-31-2023, 09:12 AM   #1
LORDOBERON
Drives: chevrolet camaro
Valve Covers
hello All
I'm looking for a set of valve covers to dress the engine up a bit on my 21 ZL1 but I also want to be able to use the factory connections for the PCV system. any suggestions or any pics with them installed
LORDOBERON is offline   Reply With Quote
Old 10-31-2023, 09:45 AM   #2
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
Most valve cover manufactures can utilize standard NA fittings if you get to correct size and angle etc. Keep in mind all valve covers are not built the same. I just went through this and had several issues until I found the right combination of things that correct my issues after I replaced my valve covers. Keep in mind, stock valve covers for the Camaro (ZL1 in my case) have a baffle built into the, and some aftermarket valve covers have them as well, but some do not. Attached is a cutaway of a stock ZL! valve cover that shows the built in baffle.
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Old 10-31-2023, 09:58 AM   #3
LORDOBERON
which valve covers did you eventually settle on
Old 10-31-2023, 10:06 AM   #4
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
These are the Katech Cast Valve Covers... I think they are the best looking on the market, but they require the following...
1. Coil Relocation Kit (no brainer)
2. Re-Plumb PCV Hoses as the connector locations change.
3. Install a MM Wild CC (also a no brainer) IMO
4. Using a restriction fitting on the clean side of the CC as the Katech cover have no baffling.
In short, this is not an easy transformation for some... but for me, it was 100% worth it!
Old 10-31-2023, 10:30 AM   #5
LORDOBERON
That's some awesome work!! I saw those valve covers but every site i went to said they were for the 5th gen Camaro, but i see they fit the 6th gen. on the re plumbing were you able to use the factory connectors and connection points. i have elite engineering catch can installed already. i also have that same DSX SC lid
Old 10-31-2023, 10:37 AM   #6
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Much better running the TooHighPSI version in my opinion. Sexy AF and OEM level oil baffling. I would not buy a valve cover without proper oil baffling or you end up having to significantly reduce catch can flow which is counterproductive.
https://toohighpsi.com/products/vind...t-valve-covers
Joshinator99 is online now   Reply With Quote
Old 10-31-2023, 10:56 AM   #7
LORDOBERON
those are the best i've seen yet. and i like that they offer two types of connections for PCV system
Old 10-31-2023, 11:05 AM   #8
JSH
JSH's Avatar
Drives: '20 ZLE
Originally Posted by LORDOBERON View Post
hello All
How about these
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 10-31-2023, 12:16 PM   #9
SOCAL.M6.ZLE
Those look bad ass also!
Old 10-31-2023, 12:42 PM   #10
ZLRob
Super Stock
ZLRob's Avatar
Drives: Chevrolet Camaro ZL1
How about these
Where'd you get them from?
758 HP/ 804 TQ
Old 10-31-2023, 01:11 PM   #11
JSH
JSH's Avatar
Drives: '20 ZLE
Edlebrock
2020 ZL1LE A10.
Old 10-31-2023, 01:18 PM   #12
LORDOBERON
those supercharged covers are sweet!!. you have a link to them
Old 10-31-2023, 02:05 PM   #13
DevilsReject97
Nightmare
DevilsReject97's Avatar
Drives: Your mom crazy in bed
https://www.wegnerautomotive.com/custom-engraving-4/
These are pretty sweet - seen em for an LS build, was considering them for my SS. Pricey, but I think they really look fantastic..
Old 10-31-2023, 02:15 PM   #14
2023_ZL1-AUTO
Drives: 2023 ZL1
The same ones that SOCAL.M6.ZLE selected, that's where I got the idea for the one I have now. You can view my entire build thread here:
https://www.camaro6.com/forums/showthread.php?t=611982
But, I also added a catch can, this is where my issue showed itself. But I'm not sure the issue was only related to adding the valve covers with no baffles and adding the catch can too. I did get the issue resolved with a lot of help from vendors and members here giving advice. My selection was between the Katech's valve covers I already installed or the DSX Billet valve covers that have baffles.
https://dsxtuning.com/products/dsx-b...33206558752848
Good luck !
