Old 09-26-2023, 01:52 PM   #1
monahamatt
Drives: 2016 Chevy Camaro 2SS
Wheel & Tire Fitment
Hey everyone! I just picked up a 2016 Camaro 2SS with 6k miles about a month ago and am loving the car. My only issue is it currently has 22” rims with low profile summer tires on it which rub a little when turning hard and aren’t the best for ride quality.
I am looking to do a 20” square setup but have never bought aftermarket wheels so I’m not sure what will fit and I’m afraid of making an expensive mistake. I’m looking at 20x9 +38 offset all around but I’m getting mixed opinions as to whether this will fit in the front on a 275/35/20 tire. Any and all input is appreciated! Looking for no rubbing scraping or any issues. Thanks.
-Matt
monahamatt is offline   Reply With Quote
Old 09-26-2023, 01:57 PM   #2
S.Macias
Monterey County Camaros
S.Macias's Avatar
Drives: Stock 2016 Camaro V6
If your running a 275 front you should go with a 20x9.5 or a 20x10. The 9" is too small.
I currently run a 275/35r20 on the fronts and 305/30/r20 on the rears with 5mm spacers all around. No issues with rubbing.
Instagram: @smaciasracing
S.Macias is offline   Reply With Quote
Old 09-26-2023, 02:00 PM   #3
monahamatt
Got it, I’ll look into that thank you! The main confusion for me is offsets as I’m not sure what will fit. Is there a range I should be looking for that is safe to fit in front and rear?
Old 09-28-2023, 09:12 PM   #4
camaro99
camaro99's Avatar
Drives: Angry Dorothy II 2016 2SS
looking for 2 rear zl1 wheels.
thanks.
camaro99 is offline   Reply With Quote
Old 09-29-2023, 02:48 PM   #5
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
You don't need spacers with 305/30r20 on the back
Old 09-29-2023, 02:52 PM   #6
FlukeSS
FlukeSS's Avatar
Rear offset for 1le sizes is 43mm
Front offset for 1le sizes is 20mm
https://www.wheel-size.com/size/chevrolet/camaro/2020/
2016 uses same offsets as 2020. Even non 1le use same offsets. Range tolerance is about (2mm to 4mm?) from numbers I provided. Front offset has to be correct for 6 piston brakes. 4 piston has no issue with 1le numbers.
I would recommend a 19" square setup.
Rather than 20" because it gives more options and availability for high performance tires and cheaper prices.
Check Apex site for square setup numbers
Old 09-29-2023, 03:09 PM   #7
S.Macias
S.Macias's Avatar
Like the slightly wider look plus it corrects the rear offset from 43 to 38
Old 10-01-2023, 07:33 PM   #8
FlukeSS
FlukeSS's Avatar
I don't have spacers on my car, granted I don't have a 1LE but I doubt it matters all that much, but to each their own I guess. I took 1LE sizes and used those as a maximum reference, in which case you do not need spacers on 1LE's with 1LE sizes on the rear. They are built from the factory without spacers in those tire sizes. Can you go lower, yes, there is a range tolerance, can you go higher? Yes, there is a range tolerance but from the factory its 43mm not 38. 38mm borders on being too small of an offset, and if you add 5mm spacer that comes to 43mm. So I don't understand how you can correct a factory design offset of 43mm? If you use 315's on the back you will need a 4-5mm spacer. In addition to 315's you will need to relocate the wire harness as well.
Old 10-01-2023, 07:47 PM   #9
S.Macias
S.Macias's Avatar
I didn't need them either. Preferred them though. At 5mm all around it gave me that peace of mind the front tires won't rub the wheel well or that off chance I could damage the driver side rear harness (even though I did relocate it). And 5mm still gives me 9 full turns on the lugs and as hard as I push the car I haven't had any issues.
Old 10-01-2023, 07:51 PM   #10
FlukeSS
FlukeSS's Avatar
Fair enough.
fitment, rubbing, square, wheels and tires
