Old 09-20-2023, 06:20 PM   #1
JSH
JSH's Avatar
Drives: '20 ZLE
ZL1 Ram Air Hood?
I'm in the process of doing the grill snorkel and removing the rain/snow blocker behind the upper grill and driver's side headlight, but my question is, does anyone know of a hood insert that directs fresh air onto the engine?
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct.
1116/967.
1.35/9.25/151 at 3500 ft. (only one pass)
15" conversion/MT ET Street R 325/50R15.
Old 09-20-2023, 07:10 PM   #2
ZLElvira
Waiting 4 A Point By!
ZLElvira's Avatar
Drives: 2020 ZLE, C8 Z06-Z07 2LT Carbon
Cool
Are you referring to this product?
https://www.velossatechdesign.com/pr...intake-snorkel
ZLElvira is offline   Reply With Quote
Old 09-20-2023, 07:11 PM   #3
RamAir02
Shadow Gray '19 ZLE M6
RamAir02's Avatar
Drives: '19 ZL1 1LE M6
Typically, proper "ram air" is plumbed to the intake. I'm not sure you'd notice much reduction in temps with a scoop blowing air onto the engine.
The ZL1 already has a heat extractor to remove warm air from under the hood. To reduce underhood temps, your best bet is probably adding additional heat extractors to the hood. Several folks on the forum have added heat extractors to the hood. Some have added to the fenders as well.
YouTube
Old 09-20-2023, 07:12 PM   #4
FarmerFran
FarmerFran's Avatar
The right side pedal?
Sorry could not resist.
But I bet you could print one, either a COWL or somehow duct it up from the grill area. What you thinking? I might be able to draw one up.
2023 Camaro ZL1 Vert TR-6060 Sharkskin "Sharky"
Firecracker Red Wrangler Willys, 3.6L eTorque, 850RE 8 speed automatic, 25W Willys package, Technology Group, Convenience Group (aka $600 garage door opener), Cold weather Group, Trailer Tow and HD electric group with AUX switches, 3 piece black freedom top.
Old 09-20-2023, 08:35 PM   #5
JSH
JSH's Avatar
Drives: '20 ZLE
Originally Posted by ZLElvira View Post
Yes. Do you use it?
'20 ZL1 1LE A10.
1116/967.
Old 09-20-2023, 08:40 PM   #6
JSH
JSH's Avatar
Drives: '20 ZLE
Sorry, I'm not following you.
I'm thinking of basically the ZL1 insert with an opening. A good carbon fiber craftsman could modify the stock unit I'm sure.
'20 ZL1 1LE A10.
1116/967.
