Old 09-15-2023, 07:29 AM   #1
Briland_1LE
Briland_1LE's Avatar
Drives: 2020 Camaro SS 1LE
Most Track Time
Who has the most track time/mileage on their mostly stock engine. I'm curious how some of the higher mileage heavily tracked LT1s or LT4s hold up. I put a lot of mileage on my car and I track it at many events each year so if there's anything I need to look out for in the next couple of years let me know.
Currently at 47k miles and probably 15-20 track hours with only fluid/brake changes needed.
Briland_1LE is offline   Reply With Quote
Old 09-17-2023, 06:01 PM   #2
LESS1
Drives: Chevy Camaro
I am up to ~ 9K on track miles and 12.5K total mileage. The car was bought as a track toy and sees very limited street use other than driving to track days.
LESS1 is offline   Reply With Quote
Old 09-17-2023, 08:10 PM   #3
RamAir02
Shadow Gray '19 ZLE M6
RamAir02's Avatar
Drives: '19 ZL1 1LE M6
14.5k miles on the car. Almost all are on track or driving to/from. Approximately 50 track hours on the car. She's rarely driven on the street and stays in the garage between track events.
All fluids are changed on the correct intervals or sooner. The only other maintenance I've had to do outside of the typical (brakes, tires, fluids, alignments) has been spark plugs. I was having misfires on cylinder 2 earlier this summer. I went one step colder for the new plugs.
YouTube
Old 09-18-2023, 06:36 AM   #4
Twizzty
Twizzty's Avatar
Drives: 2021 Camaro 1SS 1LE
I have 22k miles between street and HPDE and about 45 hours total track time in the last 2 years. Have only done fluids, brakes, and tires at normal track intervals. Seems to hold up well from it's monthly beatings!
2016 Focus RS MT - Sold
2018 Mustang GT A10 - Sold
2021 Camaro 1SS 1LE MT
2023 CX-50 Meridian Turbo
2023 KTM Duke 890 GP
Twizzty is offline   Reply With Quote
Old 09-18-2023, 07:17 AM   #5
MechanicalEng
MechanicalEng's Avatar
Drives: SS1LE
I got my SS1LE brand new, have done all the maintenances at or before the recommended intervals for track use. So far have about 80hrs of track time, 13.xxx miles total from driving to and from the track + track miles. Not a Daily Driver. My car is and has always been 100% stock, and have only used the stock 3S tires (never used R-Comp)
Besides a failed Condenser, 0 issues.
MechanicalEng is offline   Reply With Quote
Old 09-18-2023, 02:54 PM   #6
Christian1LE
Drives: 2004 BMW 330CI, 2022 1SS 1LE
I'm at just under 10k miles with about half of those being on the track. Car is mostly trailered at this point and doesn't see the road much. All stock engine wise and also 0 issues for me. I run slicks for time trial and SC3's for everything else.
Only maintenance I've done are:
Brakes, all fluids, front rotors, alignments.
Christian1LE is offline   Reply With Quote
Old 09-18-2023, 05:37 PM   #7
GreenZLE
Drives: 2020 Rally Green ZL1-1LE
I'm at 31,000 miles and 6 1/2 track events. The car doesnt use any oil. I've had 2 issues. At 20K, the bearings in the supercharger (warranty covered) started making noise and last month at Putnam Park, the car became limited to 85mph due to loss of communication with the suspension control module. Its currently at the dealership getting repaired. I've changed the oil after every track event and whenever it got down to 50%. The trans fluid has been changed twice and the rear diff 3 times. I also run at least 1 pint of SRF through the brake system after every event.
GreenZLE is offline   Reply With Quote
Old 09-19-2023, 07:14 AM   #8
gp45
Drives: 22 SS 1LE
8k miles to and from the track only. I have a steering vibration while braking. I just put new rotors and brake pads and it's still there. Any ideas?
Wheels are balanced correctly.
gp45 is offline   Reply With Quote
Old 09-19-2023, 03:28 PM   #9
Christian1LE
I would start by making sure all your front suspension components are tight, including the strut in the engine bay, also check for bearing play.
Tires can always spin on the rim, but you would usually notice that at high speed. I would also check to make sure your wheels aren't bent.
Old 09-27-2023, 09:19 AM   #10
nasbagoat
Drives: 17 SW 1LE
At 62 track days:
Component failures:
Rear toe links (play in ball joints)
1 rear hub (factory installed mounting bolts backed out)
2 rear mag ride shocks (leaking)
2 front forwards lower links (liquid filled bushings burst)
oil pan leak (tigherned bolts)
Preventative repairs:
All hub bearings
Rebuilt front Calipers
nasbagoat is offline   Reply With Quote
