Old 09-01-2023, 11:50 AM   #1
olrocker
olrocker's Avatar
Drives: People crazy with my sexiness
Electronic parking brakes
Having driven stick my whole life I'm thinking about the electronic parking brake and just wondering, well, why?
I totally get automatic parking brake releases with an automatic transmission, Cadillac has had them since the '50s using vacuum and then when when you take the transmission out of park it pops the lock gear of the parking brake pedal. But electronic parking brakes? On a manual transmission?
I am a bit perplexed here.
Purchase order submitted on 6/23/23
Received and purchased 9/8/2023
2024 2SS 6MT coupe
Sharkskin/Light gray
Moonroof/Navi/NPP/Mag Ride/Red Brake Calipers
Gray painted split spoke wheels
Illuminated footwells/illuminated bowtie
olrocker is offline   Reply With Quote
Old 09-01-2023, 12:12 PM   #2
NOTSINCE57
Drives: '23 1SS 1LE-Sharkskin M6
Everything is perplexing these days, never thought about being perplexed about the electronic parking brake until now. Sure wouldn't mind a manual puller with my manual shifter, but you get used to it. Congrats on the '24 coming in soon.
NOTSINCE57 is offline   Reply With Quote
Old 09-01-2023, 12:32 PM   #3
LTfun
Drives: 2022 LT1, 1981 320i
I'm guessing it was a space issue with the good ole Tremec. Definitely would have preferred an "analog" parking brake.
LTfun is offline   Reply With Quote
Old 09-01-2023, 12:36 PM   #4
Need4Camaro
Drives: '17 Camaro 2SS & '99 Camaro Z28
Nah, most new cars have this feature today. My Toyota Camry has it too. It's just easier and cheaper from an engineering and parts perspective to keep everything standardized.
Need4Camaro is offline   Reply With Quote
Old 09-01-2023, 12:48 PM   #5
Tbone98
Tbone98's Avatar
Drives: 2023 Sierra AT4, 2024 Camaro 2SS
Off topic, so I apologize, but "perplexing" struck me
Even more perplexing to me is getting an a10 in a LT1 or LT4. The whole reason I ordered my car is so I can rip through the gears manually like when I was a teenager and paddle shifters do not count.
Like, I'm not calling anyone out for it bc to each's own, but please explain. Is it track related?
Tbone98 is offline   Reply With Quote
Old 09-01-2023, 12:50 PM   #6
dpevans
Drives: 2024 Riverside Blue 2SS 1LE
I personally think they are easier to work on, no more adjusting cables or taking cables off when you change calipers. I like em.
dpevans is offline   Reply With Quote
Old 09-01-2023, 01:06 PM   #7
olrocker
olrocker's Avatar
As I'm sure most of you who've driven stick as long (or longer) as I have, you understand where I'm coming from - the fact I can literally move a car without having to start it or even have the keys with me it a total bonus with stick shifts. If you want to just push it a couple feet to get your yard equipment out of the garage, or get around it if it's in the way, you can do it quickly and easily even if your keys are in the house.
And as I see it, this pretty much ends all possibility of clutch popping a dead battery unless you park it in gear without the brake on.
2024 2SS 6MT coupe
Old 09-01-2023, 01:08 PM   #8
olrocker
olrocker's Avatar
Thanks! I'm getting antsy waiting for it
2024 2SS 6MT coupe
Old 09-01-2023, 01:14 PM   #9
ctrlz
It's a space consideration, mainly integrating the lever (and its support) into the cabin. The manual unit has to apply a lot of force (and needs a bit of space), whereas a button just take up some space on the console.
Gen6 camaros have two different types of parking brakes. The "cable pull" type where pulling on the button causes a motor to tighten cables attached to mini-drum brakes in the rear wheel rotors. the other is the screw/piston type which uses a motor integrated in the rear caliper to drive the piston so the pads clamp the rear rotor. I don't think brembros support the screw/piston technology. On my 2SS I can hear the cable pull motor every time i park.
Old 09-01-2023, 02:04 PM   #10
JT6Speed
JT6Speed's Avatar
Drives: 2023 Camaro 1SS M6
Just so you know, the brake can be taken off with the car just in accessory. Yes, I know you still need the key, but at least the car can be moved without starting it. I've done this for reasons like you mentioned, just to get the car out of the way without having to necessarily start it up and shut it right back off.
I'd absolutely prefer a normal hand brake as well, but it's not surprising they did it this way. Look what Dodge does, using an old school pedal release. I guess the hill hold function makes it less of a necessity as well.
Black 2023 Camaro 1SS Coupe M6
Ordered: April 2022-----Built: July 2022-----Delivered: September 2022
-Dual-Mode Exhaust (NPP)
-Red Painted Calipers (J6F)
-5 Split Spoke Bright Silver Painted Aluminum Wheels (56W)
-Chrome Camaro Logo Fender Badge
-Second Generation Front Splitter in Satin Black
JT6Speed is offline   Reply With Quote
Old 09-01-2023, 02:14 PM   #11
BatMobileLT1
BatMobileLT1's Avatar
Drives: 2023 Camaro LT1 M6
To me the best reason for the electronic parking brake is it allows for the manual transmission hill hold feature which is very convenient and works very well.
It is really needed these days where almost every has an automatic and most seem to have no idea that they don't need to creep up to inches from your rear bumper on an uphill to a traffic light.
2023 Black LT1 – M6, Dual Mode Exhaust, Sunroof, Tech Pkg w/Bose Audio, Red Front Brake Calipers, Carbon Flash Wheels, Ground Effects & RS Pkg
Added after delivery: Continental ExtCont DWS06+ Tires: 245/40/20 Front & 275/35/20 w/9.5” Rear Wheels, Red Rear MGP Caliper Covers
BatMobileLT1 is offline   Reply With Quote
Old 09-01-2023, 02:14 PM   #12
Gen6cyl
Drives: Chevy Camaro 2021 ,rs, v6, manual
I don't get along with the hill hold, makes it harder for me. I deleted it long ago but it came back.
Gen6cyl is offline   Reply With Quote
Old 09-01-2023, 02:21 PM   #13
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
Maybe I can help with the confusion-
- Bad back, bad knee, hip, foot, sciatica. Mild sciatica and intermittent left leg weakness for me.
- Shitty traffic. I’m in the suburbs 20 miles outside of Boston, traffic can very easily ruin what should be fun day of driving (more than not). Now, I just relax.
-The A10 in my LT1 is super responsive. The paddles, in my opinion, are for the most part useless in the A10. Too many gears and sport auto mode is just that good. If the tranny wasn’t as good as it is, I would have passed and gone the Audi or BMW route.
I still may buy a used beater M6, after everything turns to crap economy wise (if it happens). Depends on pricing, a second fun car that could be driven even less than the existing A10 keeper, would have to be a great deal.
Old 09-01-2023, 02:57 PM   #14
olrocker
olrocker's Avatar
But hill hold is really like training wheels. Good for teaching young kids when they're first learning to drive stick, but after you've driven it a while you don't need them. Then they just get in your way if you become a serious avid cycler.
2024 2SS 6MT coupe
