Old 08-24-2023, 11:23 AM   #1
NiteBlitz
Drives: Camaro ZL1
Had some Codes Pop Up recently
P2096 and P2098
Post Catalyst Fuel Trim System Too Lean Bank 1 and Bank 2.
I've had the header done about 1.5 years ago, if not longer. Was running fine and no check engine light since 2 weeks ago. First I thought it was a bad batch of fuel. So I already refueled 3 times and cleared codes. Codes pop back up within 30 minutes of driving or hitting the throttle hard.
PS the car does not have any cats.
Could it be the sensors, any advice would be appreciated, thanks
NiteBlitz is offline   Reply With Quote
Old 08-24-2023, 03:25 PM   #2
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
Have you tested and looked for intake/air leaks post Mass Airflow sensor? I had those codes and it was driving me and my tuner crazy. Came to find out I have a PCV hoses was lose and was allowing air in after the MAF sensor. Once I fixed that The codes cleared after a few different driving sessions.
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Old 08-24-2023, 03:52 PM   #3
NiteBlitz
Drives: Camaro ZL1
I have just visually inspected around the engine bay. I am probably going to end up taking it to a mechanic to take a look, but wanted to see if there was a simple fix I can do myself first.
Old 08-24-2023, 04:09 PM   #4
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
Just change the downstream sensors, with no cats it’s expected and it will be cheaper than getting it diagnosed to discover the inevitable
Old 08-24-2023, 04:19 PM   #5
NiteBlitz
Drives: Camaro ZL1
is this the part GM Part # 12655677?
Thanks in advance
Old 08-24-2023, 04:30 PM   #6
CalgaryZL1
CalgaryZL1's Avatar
Yes, that is the right part number for both factory upper and lower
Old 08-28-2023, 10:38 AM   #7
NiteBlitz
Drives: Camaro ZL1
Thank you
Old 08-28-2023, 10:58 AM   #8
ctrlz
Originally Posted by NiteBlitz View Post
P2096 and P2098
Post cat sensor is seeing more oxygen than expected. ECM is reading that as "lean." What has actually happened is cat converters have been removed, and now oxygen that would've been used by the converter is still in the exhaust stream.
If it worked before you can try replacing the sensors. I would probably try one of the cheater harnesses that can be plugged in place of the O2 sensor and always give an in-range reading.
Old 08-28-2023, 02:05 PM   #9
Evansa22
Evansa22's Avatar
Drives: 2018 HBM ZLE
With no cats, shouldn't these codes be turned off? Downstream o2's monitor the cats, which you don't have. As long as the upstream o2 readings are good, would think downstream's should be disabled.
Old 08-29-2023, 08:17 AM   #10
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Log your fuel trim data. If long terms are excessively positive(+25% or higher at idle) then you have a vacuum leak or unmetered air getting in the system.
Old 08-29-2023, 10:19 AM   #11
ctrlz
As long as the upstream o2 readings are good, would think downstreams should be disabled.
Sounds like a plan to me.
I did get the impression OP has deleted both primary and secondary converters.
Old 09-21-2023, 02:05 PM   #12
NiteBlitz
Drives: Camaro ZL1
Update
Swapped out the O2 Sensors, cleared code. All good 2 days and counting.
