6th Gen Camaro Automatic Transmission Rebuild
I am anticipating that my current A10 will fail at these power levels, which will require a rebuild. In fact, perhaps I should send it in over the winter, broken or not.
So, the question is, who are the top-tier transmission shops?
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO. 15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR. 100 octane: 1045hp/1055tq. 100 octane + Alky MAF Meth (1) 10+: |
Petro-sexual
I think I saw Andrew at CSP talk about a rebuilder in one of his more recent videos.
IF - you wanted to ship your car to Maryland, Late Model Performance is now building 10-speeds, in house, but will only do it with the car there, and will only tune for that tranny.
![]() Drives: 2022 Camaro LT1 A10 Join Date: Nov 2015
While I am new to the LT platform, THIS is one of the reasons I was originally going to stay away from these cars and opt for an older platform with more support. The top builders we knew from the past 4l60, 4L80 and so on do not support the newer stuff. If I was in your position I would take a look at Circle D trans though. If I ever put a stall in this car it will probably be from CD. Not just because they make good converters but also because the support is limited from what I have seen. Again, I am new and could be ignorance on my part.
I'll be paying attention to what you do
2022 Camaro LT1 A10 - Drag Pack/Corsa double X pipe/AWE track axleback -11.849@118.67MPH/1.798 60' 2001 Camaro SS A4 - HCI/Stall/Bolt-on/Gear/Tune/DR/Diet - 429HP/392TQ - 10.99@123.58MPH/1.584 60' 1998 Camaro Z28 A4 - Bolt-on 1999 Camaro Z28 A4 - Stock |
#4 | |
Moderator
Circle D converter is a waste of time on a PD blower/10 speed car.
Tim King of TK Performance in Ohio?
2020 ZL1LE A10.
#6 | |
![]() ![]() ![]() ![]() Drives: 2019 Camaro Z-28 Join Date: Jul 2010
You can buy an A10 from Chevy High Performance Parts and it will come with a 12 month warranty for about 4K (after credit for your A10 Core). It comes with fluid and a NEW convertor which is good because I ballooned my other one. With all this considered , It didnt make sense to me then to pay 3K for a rebuild. https://www.chevrolet.com/performanc...ssions/10l90-e Now a REBUILD might make sense for a much higher HP application but I am about 700HP at the motor and maybe 550 TQ. They have better clutches you can put in them and also we have a guy down here in my area than can machine the case to be able to hold MORE clutches. These are used primarily in twin turbo heavy assed trucks making 1500 HP or so. The STOCK A10 can easily handle 900-1000HP as long as you doing proper maintenance.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 Last edited by sr71bb; 08-10-2023 at 03:17 PM. |
#7 | |
And Circle D Specialties for a 10L80 stall for me https://www.circledspecialties.com/c...rque-converter Obviously they look like they maybe the same company or have some relation, but they are two different places of business. Not sure if you knew that or you already had info on CDT being totally worthless ![]() If you're saying they suck I'd like to know so I can avoid that fiasco
#8 | |
2020 ZL1LE A10.
#9 | |
On the other hand, it's not giving me any indication that that it dislikes what I'm doing to it now.
2020 ZL1LE A10.
#10 | ||
Moderator
Yep
#11 |
![]() Drives: 2018 ZL1 A10 NFG 2019 COPO 350 SC Join Date: Feb 2018
I will let you know how my rebuilt tranny does after my new motor gets tuned! LMP of Md did the rebuild and I have a Circle D converter in it. I should be north of 4 digits at the wheels I hope! lol
2019 COPO #32
350 SC 8.25 167MPH 2018 ZL1-NFG-A10 388CI L8T 9.32 147MPH |
#12 |
Did you go with a higher than stock stall speed? Stock is 2500 I believe?
#13 |
Just a tad higher, 3000
2019 COPO #32
#14 |
![]() Drives: 2017 Chevrolet Camaro ZL1 Join Date: Jul 2018
Stock will hold for a little while, depending on how you are using the car. My stock one started going in the mid-900 RWHP range after 50 passes or so. It always starts with slipping in the higher gears.
Pure Drivetrain Solutions has been building mine for a couple years. I sort of volunteered to be their R&D car for the 10L90 and it has consistently been getting better. I have smoked a converter and broke some other unrelated stuff, but the transmission has been solid for a while.
2017 ZL1 - PB 7.85 @ 175 MPH @ 3682 lbs @ 1313 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned |
