![]() ![]() Drives: 17' 1SS 1LE GBA-Black Join Date: Mar 2017
Need Help - LT4 Blower Lid Bolts/ Studs OE/GM Part#s
Need a set of new bolts / studs for the lid.
This should include the plastic inserts as well. Can anyone provide me the exact GM Part#s for the 20 Bolts & Studs: - Charge Air Cooler Cover Ball Stud : Qty. 4 - Charge Air Cooler Cover Edouble Ended Stud: Qty. 5 - Charge Air Cooler Cover Bolt: Qty: 11 - Plastic inserts: Qty: 20 https://www.repairprocedures.com/ser...3_4042606.html
Geoff
Drives: 2022 SS 1LE Join Date: May 2013
Eldi, the lid bolts are reusable, so are the black plastic retainers. There are no flat washers
However the blower to head bolts are single use, buy kit 12679527, it includes the gaskets, TTY bolts along with both the flat and black washers. - Charge Air Cooler Cover Ball Stud : Qty. 4 did not see these in the drawings or on my car (2020 ZL1) - Charge Air Cooler Cover double Ended Stud: Qty. 5 11610126 - Charge Air Cooler Cover Bolt: Qty: 11 qty 15 11611992 - Plastic inserts: Qty: 20 11518792
Thanks Geoff !
I think that the 4 Ball stud bolts are not correct for the LT4 SC lid (this is why you would not find them for your ZL1). I think that they are used in conjunction with the plastic engine covers (with the "Camaro" logo) on the LT1 /SS. The covers plug on these ball-ends. Plastic retainers! Valuable information. I could not find them in the drawings, but know that they must be used with the lid bolts and studs. Where did you find their Part# from? |
