Old 06-04-2023, 05:02 PM   #1
Cheese ZL1
Drives: 23 Camaro ZL1
23 Camaro ZL1 Jack Pads
Anyone have any suggestions for jack pads for my 23 Camaro ZL?
Cheese ZL1 is offline   Reply With Quote
Old 06-04-2023, 05:14 PM   #2
JSH
JSH's Avatar
Drives: '20 ZLE
I just put a set of ZL1 add-ons on mine last week
https://zl1addons.com/collections/ca...lton-lift-pads
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 06-04-2023, 05:42 PM   #3
Vigilante375
Drives: 2018 Camaro ZL1
ZL1 add-ons as mentioned. Tried and true and gets the job done.
Old 06-04-2023, 08:13 PM   #4
Broooster
Drives: Sharkskin Metallic ZL1
No issues with the ones I bought off of Amazon for 30 some bucks. I did get myself longer set screws so I was using all of the the threaded part of the hole, even when tightened up.
Broooster is offline   Reply With Quote
Old 06-04-2023, 08:39 PM   #5
cvp33
America FVCK Yeah!
cvp33's Avatar
Drives: 2024 Z06
Same
https://a.co/d/2xGo8EX
1997 Z28 Anniversary Edition SOLD
2004 GTO ORDER CANCELLED
2004 CTS-V SOLD
2005 CTS-V SOLD
2006 300C SRT-8 SOLD
2010 CTS-V SOLD
2012 CTS-V coupe SOLD
2013 ZL1 vert SOLD
2016 Callaway Z06 SOLD
2019 Z06 SOLD
2021 ZL1 1LE SOLD
cvp33 is offline   Reply With Quote
Old 06-05-2023, 03:38 AM   #6
Brettallen59
Brettallen59's Avatar
Drives: 2023 ZL1 - 1969 SS396
Smart idea utilizing max threads for set-screw strength. I also purchased a set through ZL1 Addons. When I laid down to do the install, I saw what a good move it is to install these. There is utterly no where to place a floor jack that would not cause damage IMO.
Brett.....
2023 Code ZL1 1AL37 - Track Pack PPF - Jade Obsidian Graphene Pro Ceramic Coating
1969 Code X66 SS396 - RS Conversion - Holley Terminator TB w/ HP ECU EFI - TKO600 - 3.73 Posi.
Brettallen59 is offline   Reply With Quote
Old 06-05-2023, 06:35 AM   #7
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
I concur the set for ~$30 on Amazon.
Old 06-05-2023, 07:38 AM   #8
NashZL1
Drives: 2022 Camaro ZL1
I got the 30 dollar ones off ebay. The set screws tips seemed too "sharp" or "pointy" so I filed the tips down a bit . They fit great and have been utilized several times with no problem.
Randy in Nashville
2022 Chevrolet Camaro ZL1 A10
2020 Ford Mustang Shelby GT500
2020 Genesis G90 Ultimate
2018 Porsche 718 Cayman GTS
2019 Mercedes-Benz SL450
2017 Corvette Grand Sport A8
2024 Honda Civic Touring
1971 Datsun 240Z
NashZL1 is offline   Reply With Quote
Old 06-05-2023, 08:47 AM   #9
NYTMARE23
NYTMARE23
NYTMARE23's Avatar
Drives: Black 2023 ZL1 A10
3 stupid questions about the jack pads:
1. Can I install them with the car(tires) sitting on the ground or does it(the car)need to be jacked up a bit?
2. Once they are put on, do you guys just leave them on or do you only put them on when needed to jack the car up?
3. Where EXACTLY do each of the 4 of them go on underneath the car?
Thanks ahead of time!!
2023 A10 ZL1 "NYTMARE"
NYTMARE23 is offline   Reply With Quote
Old 06-05-2023, 09:38 AM   #10
Vigilante375
1) Yes. You can install them without the car needing to be lifted.
2) With the ZL1 add-ons and similar variants, you leave them on. One type is magnetic and the other type has a set screw to hold it in place. I have the set screw version and never have taken them off or had any fall off.
3) There are 2 lift points on each side. Best way to tell you is to look under the car and you'll see a very obvious gap in the side skirt. There are 2 pictures in this thread that show where you should jack the car up: https://www.camaro6.com/forums/showthread.php?t=548253
Old 06-05-2023, 09:59 AM   #11
NYTMARE23
NYTMARE23
NYTMARE23's Avatar
Thank you!! Appreciate the answers and info!!
Old 06-09-2023, 07:40 AM   #12
Badmojo
aka BeastZL1
Badmojo's Avatar
ZL1 Addons Stealth lift pads
https://youtu.be/SmFUekbDQFQ
with the thumbnail
Sent from my iPhone using Tapatalk Pro
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
Old 06-09-2023, 09:09 AM   #13
DangerZL1
Drives: 2023 Black ZL1 Auto
I have the stealth version on mine. Highly recommended!
Old 06-10-2023, 04:27 PM   #14
Cheese ZL1
I ordered the ZL1 Adonis jack pads…I’ll let you know when they arrive
Thank you
