Old 02-16-2019, 06:54 AM   #1
Moniker
Drives: ZL1
Where are the correct lifting points
Where are the correct lifting points for a 4 post hoist? I know the pinch welds can be sued with various jack pads like the ZL1 Add-ons for jacking up the car at home. There seems to be a lot of controversy on where and how to lift the car. I had a 5th gen ZL1 and the Owner’s manual had a clear lifting procedure. I also owned a C5-Z06 also clear lifting procedure. I contacted Chevrolet directly and asked about the lifting procedure. They refused to answer but said they would tell the procedure to a Dealer of my choice. Wow! I don’t get it? The CTS-V has the same chassis and so does the 1LE there must be a clear procedure?
Moniker is offline   Reply With Quote
Old 02-16-2019, 08:20 AM   #2
Cobaltct
Drives: 2018 camaro ZL1 in Nightfall Grey
I would like to know this as well....
Cobaltct is offline   Reply With Quote
Old 02-16-2019, 09:19 AM   #3
unavailablezl1
unavailablezl1's Avatar
Drives: 2019 Silverado Z71 6.2L A10
THere are a lot of posts on this subject. Some being mine. Search and if you cannot find them I can post again
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's.
Past Rides
2017 M6 Camaro ZL1 Hyper Blue
2016 M6 GT350 White with blue strips
2014 M6 Mustang GT Premium Track Pack Ruby Red
2012 M6 M3 Melbourne Red Metallic
unavailablezl1 is offline   Reply With Quote
Old 02-16-2019, 09:26 AM   #4
kwav8r
Flyin NOE
Drives: 2018 ZL1 (A10)
you can use either the pinch welds (highly recommend the ZL-1 Addons adapters) or the factory lift points.
Old 02-16-2019, 09:52 AM   #5
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Lift / Jack Points noted in Yellow Boxes. In short, you are limited to the pinch weld areas.
There are some factory PLP but you would need large pads made to right shape and pinned to safely use them without crushing ONE metal thickness around them.
ing for grip.
http://www.motorsportsne.com/
Old 02-16-2019, 11:38 AM   #6
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
+1 this.
When you get under the car you’ll see where the factory lifted the car (rubbed paint) but I wouldn’t trust a shop to do it right unless they had the right adapters.... and most don’t.
Old 02-16-2019, 12:20 PM   #7
These are the ZL1 lift points. Note GM suggests that the outboard front pair be used for the lift, presumably the inboard ones are for jack stands.
Old 02-16-2019, 12:36 PM   #8
Moniker
Drives: ZL1
Thank you. I had seen the pinch welds location but not where to put the hoist pads.
Old 02-16-2019, 12:38 PM   #9
Moniker
Drives: ZL1
Can you tell me where you found this image? Thank you
