Old 05-21-2023, 09:57 AM   #1
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Word is don't waste your money on the LT2 manifold
Just sharing info...no dog in this hunt.
Old 05-21-2023, 10:36 AM   #2
6spdhyperblue
Drives: 2SS 1LE
Yeah his info on that intake is a head scratcher from the start. I’ll say this, I wouldn’t port the lt2.
The ports are good out of the box, I wouldn’t touch it. If he’s taking a lot of material out like porting a lt1, thatll make it lose power. So to me, the real comparison is a pray ported LT1 vs a stock LT2 with only a ported snout to match the 95mm. I’ll take the stock LT2 all day.
The reason I say this, is my track numbers match gpi dyno number gains. GM has published the results of the lt2 vs the lt1.
I really question a lot from those shops these days unfortunately
Old 05-21-2023, 10:41 AM   #3
Sillysspeed
Drives: 22 LT1
Lt2 is easy small economical gain in hp. Especially if you clearance it and add brake booster yourself. I got back to back data on same road and similar air. It was worth a tenth and 1.5mph on my stock car. No tune
Sillysspeed is offline   Reply With Quote
Old 05-21-2023, 10:47 AM   #4
6spdhyperblue
Drives: 2SS 1LE
Yep
Old 05-21-2023, 11:11 AM   #5
khcoaching
khcoaching's Avatar
Drives: 2021 1SS 1LE
For my needs, it worked amazing. I needed more power over 5800 and it delivered for road course work. Data doesn’t lie…
Red is LT2
khcoaching is offline   Reply With Quote
Old 05-21-2023, 02:58 PM   #6
Sillysspeed
Drives: 22 LT1
Originally Posted by 6spdhyperblue View Post
Also how did my blue car nearly hit 127 mph full weight with only rear seat out? Stock front wheels. I just don’t see that being possible if the LT2 lost power.
Also worth mentioning, I have a pray ported LT1 here on the shelf. It’s a good option for stock appearance. But it’s been on the shelf for like three years.
I don’t sell these so I’m not that partial as well. I will say this, there should be no money to made in porting them
If you want to sell that prey ported lt1 lmk. I went with a Procharger and had to switch back to the stock intake (lt2 won’t clear the lt4 hpfp).
Old 05-21-2023, 05:34 PM   #7
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
I tried it and my take away if you can’t afford the MSD go with the LT2. If GPI test result are accurate then I say the LT2 is worth its money for a budget minded person. Plus the look of the LT2 with cover is way better looking than the stock LT1 in a purely cosmetic point.
I think GPI covers this pretty good.
https://youtu.be/bt55yZGEdoE
There are mods that are worse or really don’t do anything. So many companies and people port, it’s like dyno runs at different shop always subjectable & and based on how well they do it. Porting makes a difference in high performance builds and not so much in low power builds IMO.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 05-21-2023, 10:40 PM   #8
s346k
s346k's Avatar
Drives: like an old lady
i went from a pray ported lt1 to a stock lt2 with a stock tb on both. the car picked up 1.5+ mph. no changes to the tune.
Old 05-22-2023, 12:07 AM   #9
red6.2
Drives: 2010 camaro
lt2 manifold makes more power than lt1 manifold! It may not be better than msd, but its a improvement over lt1. its why the c8 has it...
red6.2 is offline   Reply With Quote
Old 05-22-2023, 12:10 AM   #10
red6.2
Drives: 2010 camaro
"they're hungry!"
Old 05-22-2023, 09:04 AM   #11
KingLT1
KingLT1's Avatar
I am not saying it's not worth it. I have seen plenty of folks report gains with it over the years. I just think it's funny and had to share since it's slow in here.
If you want my opinion, I think Brett is over the "bolt-on" game and has focused his business model on selling parts that support growth and higher dollar packages. More money spent per customer. So this is just a marketing ploy to get folks to buy an MSD or Highram because in the end they better support a Heads/Cam and/or larger cube setup.
Old 05-22-2023, 09:39 AM   #12
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
Manifolds
Ok Boys well I have had a three typical combos as far as manifolds go. The STOCK LT1 manifold ran out of steam around 5800 RPM. When I switched to a LT2 manifold , it moved the power band up to roughly 6200 RPM and about 15 MORE HP. Now porting the LT2 manifold did virtually NOTHING so I dont reccommend that.
My last variation was an MSD manifold because I put in a 419 stroker motor with a fairly large cam (GPT NFT cam) and I felt like it needed MORE air . Porting THIS manifold also showed very small gains. So with THIS combo, peak power is about 6500 RPM (roughtly 580 RWHP) with stock converter and A10 tranny.
Car is a beast on a road course where RPM RARELY falls below 4800-5000 RPM.
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 05-22-2023, 09:50 AM   #13
sr71bb
sr71bb's Avatar
Manifolds
My last variation was an MSD manifold because I put in a LME 416 stroker motor with a fairly large cam (GPT NFT cam) and I felt like it needed MORE air . Porting THIS manifold also showed very small gains. So with THIS combo, peak power is about 6500 RPM (roughtly 580 RWHP) with stock converter and A10 tranny.
Retired Cars BELOW:
Old 05-22-2023, 11:25 AM   #14
jlaudio11
jlaudio11's Avatar
Drives: Chevy Camaro
He's all about porting and selling that service, the lt2 doesn't benefit from it like the other intakes do. If he isn't making money off it, no reason to push it, which I get. Going hard into why it's "so bad" is just his personality it seems.
'20 Camaro LT1
Twin 67/62 turbo 401(L8t) Texas speed forged piston & rod, BTR stg1 turbo cam, holley ultra lo, port injection, circle d 3600 stall, et street r’s on racestar recluse wheels.
1.33 3.75 5.75@122.98 1/8 pb 9.04@141 1/4 pb technically
'94 Camaro Z28 6mt cc306 cam, 4:10's, longtubes with x pipe, otr intake
jlaudio11 is offline   Reply With Quote
