![]() Drives: 2020 V6 Auto 3LT RS Join Date: Apr 2019
Front bumper guard (strip of rubber)
Is it expensive to replace? Should I just take it off?
Has anyone else ruined theirs? Thanks |
Hail to the King baby!
Drives: '19 XT4 2.0T & '22 VW Atlas 2.0T Join Date: Dec 2008
It’s called an “air dam” and it should be fastened to the lower edge of the fascia. Worst case is it is riveted on. Then you would have to drill them out and re rivet. Nuts and boots would make it easier. Might just be scrivets which would be re usable as well.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
It's held on with screws and is there for a reason. I'd replace it. They are like $20.
https://www.camaro6.com/forums/showthread.php?t=477890 |
![]() Drives: 2016 1LT 'Vert Join Date: Feb 2022
Both "inexpensive" and easy to replace.
I think the "kit" that has both sides is less than $30 and each side is held in by 6 or 7 screws (working from memory). The screws are accessable from underneath. the only problem you may have is the clearance to the ground, but definately doable with common tools (7mm hex head screws). Might be easier on jack stands and with the wheel off, but not necessary. Visability is an annoyance when positioning the new part up to the screw holes, everything's black, and it's hard to get a direct line of sight to line-up. You need to work by feel a little bit. Nothing so difficult that you'll be throwing tools, though... |
Is it one large piece or two smaller ones that meet in the middle? Thanks
#6 | |
I took them off because they look butt ugly, scrape on everything and are there mainly for some minuscule fuel economy gain. I installed a front splitter that makes up for any extra downforce these may or may not have generated. The ZL1 has much better splats under the bumper, those I wouldn't remove, but these are pretty weird. I have two sets btw if you want them ![]()
#7 |
![]() Drives: 2023 Camaro 1SS M6 Join Date: Mar 2023
They're one piece and held on by like 6 or 7 screws. I took mine off like Arpad said. From what I understand they were meant for a slight improvement of "aerodynamics" that I guess would slightly improve economy? I don't think 1LE's have them from the factory but I could be wrong.
#8 |
i am curious about the point of those....
2021 Camaro 2SS Summit White
Kooks 1-7/8 LTH with high flow cats, Corsa Extreme+ variable, Roto-Fab CAI, GPI Ported-LT2 IM, Lethal Garage Flex Fuel Sensor, Mishimoto catch can. |
#9 |
2017 HyperBlue 2SS
There are two, a left and a right. Replaced both of mine last year. They are pretty cheap and they’re supposed to help with air flow and MPG.
http://www.camaro5.com/forums/showthread.php?t=30755 2010 IBM 2LT RS......Traded for..... 2012 IBM 2SS RS......Traded for..... 2017 HBM 2SS |
#10 |
![]() Drives: Several Join Date: Jul 2018
#11 |
Thanks everyone !
#12 |
I had 2 , is this the correct replacement for my 2020 ? It’s an RS convertible if that matters. Is there a better one than OEM ?Where is best place to get?Thanks
https://www.maloufpartsxperts.com/oe...IaAn-EEALw_wcB |
#13 | |
The best replacement for these is... nothing, these are monstrous eyesores that save only a minuscule bit of fuel each mile. They also scrape and damage very easily.
#14 |
