![]() Drives: 2020 ZL1 A10; Shadow Gray Metallic Join Date: Sep 2020
Driver Side Hood Gap
The past weekend, I saw some ZLEs with rotofabs and noticed that their rotofab seals were completely smashed. My rotofab seal looks brand new, no compression on it. Took a look at my hood alignment, and sure enough it wasn't aligned.
I've read the posts about a hood gap and hood alignment and tried to fix it myself. This is the best I could get my driver side hood gap to look like. )I've tried all combinations of loosening and tightening the torx bolts. I've tried all combinations of adjusting the rubber nubs. I've tried all combinations of adjusting the hood latch, and I'm not sure what else to improve it. What worked best was raising the passenger side hood latch as far up as it would go, lowering the driver side hood latch as far down as it would go, raising the leftmost passenger rubber nub as far as it would go, loosening the passenger bolt, and tightening the driver side torx bolt. Any other thoughts or recommendations? I have the bumper to bumper warranty until July, but the dealer is an hour away and I'm 50/50 if they'll even fix it under warranty (ZLE aero installed and rotofab CAI) |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
Mine looks the same way, I think it's common to ZL1s.
Need to loosen the hood mounts back by the cowl and move the back of the hood towards the driver side.
where the hood bolts to the hinges.
![]() ![]() ![]() ![]() Drives: 2023 ZL1 - Beast Build Join Date: Dec 2022
On my (I showed this on my post) My hood gap was larger on the drivers side vs the passenger side. found out it was due to the under hood scoop rain deflector making contact the the round air intake tube of the roto-fab. Once I shave a small amount of the rain deflector off, my hood closed properly and equally on both the passenger and drivers side.
#7 | |
#8 | |
#9 |
I had seen that image but couldn't tell what it was referencing by the 4 hood hinge nuts. 2 hinge nuts by the hydraulic arms, got it.
#10 |
![]() Drives: Canadian 2019 BLACK ZL1 Join Date: Feb 2020
Mine is not centered on the Carbon fiber part…
#11 | |
Here is my post talking about this: https://www.camaro6.com/forums/showp...4&postcount=93 |
#12 | |
#13 |
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
My ZL1 has a slight driver side gap with the RotoFab but doesn’t have an effect on closing the hood. Mine has been on the car since 2020 so I would say the rubber gasket is compressed enough now.
