Old 04-27-2023, 12:12 PM   #1
Berto24
Berto24's Avatar
Drives: Camaro SS
Cluster Oil Pressure 0
So yesterday when for a cruise with the Pro charger already installed, everything was going well until I get back home, I notice the car enter in a limp mode it wouldn't rev more than 1500rpms. When I look in the cluster oil pressure was at 0 I quickly shut the car down an start diagnosing, I hook up the MPVI and open VCM scanner and to my surprise I have oil pressure in the program and I can see the oil pressure sensor voltage working. For some reason the oil pressure is not coming in the cluster.
Berto24 is offline   Reply With Quote
Old 04-27-2023, 03:16 PM   #2
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I literally just had this happen to me too. Changed the supercharger out and did a few misc cleanup items in the engine bay. Started the car for the first time this spring and 0 oil pressure on the gauge. I believe I actually have oil pressure since the car idled for 10+ minutes before I realized it (!) but still shows 0 psi. I changed the sensor and that had no effect. I’ll be digging into this tomorrow morning in depth and will let you know what I find.
Old 04-27-2023, 04:07 PM   #3
Berto24
Berto24's Avatar
Drives: Camaro SS
I just started my car again and had oil pressure on the cluster for around 40 secs and then straight to 0. No Cel or anything. I am baffled.
Old 08-11-2023, 01:42 AM   #4
Abrz_
Abrz_'s Avatar
Drives: camaro 2ss/rs
Just ran into this issue with my Zl1 after installing a 2650 and katech front cover , did you guys figure out what it was ? Or is tune related
5th gen BTR turbo 3cam, AGP twin 57s /E85/fore dual 450s/vaporworx controller
19 SS Huron speed twin 62/62 turbos
18 ZL1 2650 / port / Holley / New Era Performance stage 3 pd cam / Frankenstein ported heads 9.4 @ 151 3500da
@stalk_zl1
Abrz_ is offline   Reply With Quote
Old 08-11-2023, 05:31 AM   #5
Joshinator99
Moderator
Yep, we had missed a harness reconnection at the back of the blower. It was unrelated to oil pressure too, that was the weird part. But I suspect any open harness connection can cause that.
Old 08-11-2023, 07:30 AM   #6
Abrz_
Abrz_'s Avatar
Ahh that makes sense , I do have the evap solonoid disconnected and the cam phaser unplugged since I did the katech front cover . I’m getting tuned today maybe after turning them off in the tune they should work. That’s interesting thank you 🙏
@stalk_zl1
Old 08-11-2023, 10:43 PM   #7
Abrz_
Abrz_'s Avatar
Just an update it was fixed with the tune . Disabled some of the disconnect stuff not in use with HP tuners
@stalk_zl1
