Old 04-17-2023, 02:08 PM   #1
Nimair.ZL1
Drives: 2023 Chevy Camaro ZL1
Horsepower
Hello,
My current mods are
Camshaft (229/240 116+5)
2" long tube headers no cats
9.65" lower pulley
DMS fender tank
Stock upper pulley
HHP TCM swap
Rotofab big gulp intake
Stock upper pulley and unported sc
What would your guess be on how much RWHP I'll be making with this set up?
Nimair.ZL1 is offline   Reply With Quote
Old 04-17-2023, 02:48 PM   #2
JSH
JSH's Avatar
Drives: '20 ZLE
Originally Posted by Nimair.ZL1 View Post
Hello,
My current mods are
9.65" lower pulley
DMS fender tank
Stock upper pulley
HHP TCM swap
600-625
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 04-17-2023, 02:57 PM   #3
Nimair.ZL1
It made 654rwhp on a cold pull with the 9.06” lower pulley. They are now replacing the lower pulley with a 9.65”. 625 seems a little low.
Old 04-17-2023, 03:14 PM   #4
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Dyno numbers can vary wildly by type (load bearing vs inertia drum) and altitude correction factor. That said you’re leaving a lot on the table by not running E. Port the blower and add a bigger TB too.
Old 04-17-2023, 03:50 PM   #5
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
I guess 680 on the first pull in the morning. 650 or less after that.
Mods being installed-
Old 04-17-2023, 04:01 PM   #6
SJFGTO
Oh Oh it's Friday Night!
SJFGTO's Avatar
Drives: 2018 ZL1 1LE Nightfall Gray
660-680
Four that wanna own me
Two that wanna stone me
One says she's a friend of mine...
SJFGTO is offline   Reply With Quote
Old 04-17-2023, 04:46 PM   #7
JSH
JSH's Avatar
Drives: '20 ZLE
Yes 650 is better
2020 ZL1LE A10.
Old 04-17-2023, 05:48 PM   #8
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
700 cold
Old 04-17-2023, 05:54 PM   #9
Crusher Camaro
Drives: 19 ZL1
I have Jannetty Terminator Cam, same headers, no cats, only a 8.650 lower/stock upper, JMS voltage booster, but a 95mm throttle body with a big gulp and put down 690 whp on a nice hot Florida day.
But I was also on E40.
What fuel are you running?
I would wager 650-660 range
Crusher Camaro is offline   Reply With Quote
Old 04-17-2023, 06:32 PM   #10
Nimair.ZL1
I’m running 93 right now
Old 04-17-2023, 06:33 PM   #11
Nimair.ZL1
700 cold
I wish. I had a 9.06 lower before and with that I made 654 cold. They are replacing it with a 9.65 now so I can make more boost. I think I should be at 675ish now.
Old 04-17-2023, 08:43 PM   #12
JSH
JSH's Avatar
Drives: '20 ZLE
My OEM 1.7L build had a 9.18 (10%) lower which was as far as Hennessey would go. My reaction to a 9.65 is that it seems like too much and will generate too much heat
2020 ZL1LE A10.
Old 04-17-2023, 11:07 PM   #13
KingLT1
KingLT1's Avatar
Ahh I thought you meant the 654 was before cam. I think that is too much boost. It's only going to make more power when cold. Port the blower and give it more octane.
Old 04-18-2023, 10:01 AM   #14
Nimair.ZL1
Horsepower
So results are in!! On a cold pull it made 707RWHP with the 9.6 lower pulley and stock upper! Beyond satisfied!! Blower however is a restriction. Need to get it ported
