Old 04-17-2023, 12:20 PM   #1
steaziest
Drives: 2017 Camaro SS
Steering wheel buttons not working + issues
Bought myself a 2017 Camaro SS Manual Salvaged with 30k miles (so no dealership warranty) for a really good deal, but it has some issues.
Steering wheel buttons don’t work at all. Only cruise control which is the one to click to turn it on but not to set it. I’ve tried using it and it’s only worked one time and the rest of the times I’ve tried using cruise control it won’t set. None of my other buttons work. My rev match and horn both work.
My car is also slightly misfiring but no CEL. And I am getting trash mpg (but can’t check because my steering wheel controls don’t work lol)
Codes being thrown (but no CEL)
P0580-00 : Cruise Control Multifunction Switch Circuit Low Voltage
U0422-71 : Invalid Data Received From Body Control Module
C0914-02 : Control Module Voltage Output 1 Circuit
C0800-03 : Control Module Power Circuit
Anyone have these issues/codes as well? Any input would be appreciated. Thank you!
steaziest is offline   Reply With Quote
Old 04-17-2023, 02:38 PM   #2
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
Probably best to swap out the steering wheel control switches to see if the piece is broken or the wiring
2016 1LT v6
- Totaled
Happiness: Infinite
Old 04-17-2023, 03:22 PM   #3
Slip3Kid
Slip3Kid's Avatar
Drives: 2023 Camaro 2SS
Listen, I don't know crap, so buyer beware. Have you checked how old you battery is? Could a battery going bad cause this?
Also, why was the car salvage? If it was a flood car I would expect this kinda stuff and more.
23 2SS M6
1/30 1100
3/23 2000
3/31 3000
4/04 3400 TPW 4/17
4/19 3800
4/20 4300
4/22 5000
4/24 6000
Slip3Kid is offline   Reply With Quote
Old 04-17-2023, 04:29 PM   #4
steaziest
Any way to test it ? I mean the buttons seem to click and such but don’t work. Cruise control one did but didn’t.
Old 04-17-2023, 04:30 PM   #5
steaziest
I’ll check my battery to be safe; because my crank up start is kinda slower than it should be. It was front end damage
Old 04-17-2023, 05:03 PM   #6
easttxss
easttxss's Avatar
Drives: '16 2SS M6
You need a factory service manual so that you can do the proper checks on the system. Even then you are going to hit a dead end when it comes to module replacement as those have to be programed, unless you have your own pass through device and a subscription to GM's service system. The manual for that model is available on CD for pretty cheap on eBay. You will also need a quality scanner that can look at the body control modules.
With frontal damage, I expect air bag deployment. If that was the case, it could have damaged the buttons.
David
'16 2SS M6 black on black, SW long tube full exhaust, NPP, Roto-fab CAI, ported stock TB
'16 2SS M6 black w/Metallic black stripes, Kalahari, 6 piston front (totaled 1/22/20)
'14 Fusion Titanium 2.0T
'83 Jeep Wagoneer
easttxss is offline   Reply With Quote
Old 04-17-2023, 05:37 PM   #7
steaziest
I was thinking about taking my wheel off to check buttons first, since that seems like it could’ve been something not plugged back in or so. But I literally can’t find anything about buttons not working. It’s usually everything but not my case.
Old 04-17-2023, 06:39 PM   #8
SS_Don
SS_Don's Avatar
Drives: '22 Camaro 2SS
Checked fuses?
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4 | Range AFM Disabler
Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo | Footwell Lighting | Umbra Sequential LED Taillights
ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Banks Data Pro and Pro gauges in ZZPerformance pillar pod | Paddle shifter extensions
SS_Don is offline   Reply With Quote
Old 04-17-2023, 07:30 PM   #9
steaziest
Originally Posted by SS_Don View Post
Checked fuses?
Yup. Checked all fuses. They all seemed fine .
Old 04-17-2023, 07:54 PM   #10
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
If you don’t know what you’re doing, you may want to rethink taking the wheel off. There’s a specific procedure so that the clock spring isn’t damaged….if you damage that, you’ll have a more pressing issue. It may even be the cause of some of your issues.
https://www.dubizzle.com/blog/cars/b...your%20vehicle.
Old 04-18-2023, 05:53 AM   #11
jamala00
jamala00's Avatar
Drives: 2016 Camaro 2SS Hyper Blue Metallic
I don't have the knowledge or tools to work on the modern cars with all the electronics and such. I can only imagine that buying a car with a salvaged title could be a huge can of worms. There had to be enough damage to it for the insurance company to total it. That means what 70% of it? Good Luck, hope you're able to figure it out.
jamala00 is offline   Reply With Quote
Old 04-18-2023, 10:22 AM   #12
ctrlz
I would start by hitting ebay and getting a service manual.
As easttxss points out, I think you will need a tool which can communicate with body control modules. There are various clone tools available. Some of these will do SPS programming, although I am not sure about VIN delete and relearn.
Is there obvious damage you can report to us? Like underhood and interior, particularly the instrument panel and steering wheel?
I would try to find out what happened to this car. I would not start taking things apart without more information. Hate to open up a steering wheel only to find you have a bad module above the brake pedal which is much easier to get to.
Old 04-18-2023, 05:41 PM   #13
steaziest
Car had front end damage that didn’t look too severe, and was right before car market shot up so it seemed at its lowest value and it was salvaged. No frame damage looked as it was just a bumper fenders and headlights / front end. I’m just confused because usually u won’t have any functions working but my auto rev match works and my cruise control will turn on and off but won’t set speed to actually work. But it worked one time when I was driving and randomly tried it. don’t know if that sounds like a clockspring (I think it’s called) in the steering wheel or if it could be a short somewhere. I cleared codes and only the c0800-03 stayed.
Old 04-21-2023, 01:31 AM   #14
steaziest
No resolution yet. But I’m assuming something is either disconnected or unplugged. Not sure but will probably get it diagnosed
