Old 04-16-2023, 08:21 AM   #1
Slurpee
Slurpee's Avatar
Drives: 2020 ZL1 A10; Shadow Gray Metallic
Cold Weather Track Day Tires
The Midwest winter in the spring strikes again. I have a 3 day event at Road America this upcoming weekend, temps as of right now are a high of mid 40's. I was planning on running Pirelli DH take off slicks, but doesn't seem like a good idea with this low of temperature. I don't have a problem with warming up the slicks very cautiously, but my concern is the overnight temperatures freezing the rubber, and additional heat cycles since they will be cooling down significantly faster when off the track. Not sure what to do now.
I have 2 track days on my SC3s, but I don't think they're going to last 3 more track days. I could order a 200 or 100 TW 18" tire and hope they get here in time, but I'm not sure which to choose between Nitto, Nankang, and Toyo.
Slurpee is offline   Reply With Quote
Old 04-16-2023, 08:53 AM   #2
Baddawg53
Drives: 17 hyper blue 2SS M6
I don't have a ton of experience with different tires, so take it for what it's worth, but my nankang AR1's seem to grip very well when they're cold. No problem pushing the car by the end of the out lap. My warm up laps seem to be more for me than my car.
Baddawg53 is offline   Reply With Quote
Old 04-16-2023, 10:01 AM   #3
5.M0NSTER
5.M0NSTER's Avatar
Drives: 2018 Camaro 1SS 1LE
How are your SC3s looking? I ask because the you can run them till there is no more thread left, and then some plus they do well in cool weather.
5.M0NSTER is offline   Reply With Quote
Old 04-16-2023, 12:07 PM   #4
Slurpee
Slurpee's Avatar
Thanks. Really tough pill to swallow buying a new set of these when I have 8 sets of take offs in the garage. I read on the Porsche forums if you keep them in the hotel you can run them below 45 degrees lol.
Old 04-16-2023, 12:08 PM   #5
Slurpee
Slurpee's Avatar
They’re not terrible. The outsides definitely have way more wear. My first 2 track days on them were at -1.0 camber. Insides have plenty of life. I’m at -3.0 now. I could definitely run them at least one day, maybe 2. 3rd would be iffy.
Old 04-16-2023, 09:57 PM   #6
cdrptrks
cdrptrks's Avatar
You can arrive on the SC3s and leave them on the car overnight and put the slicks in the hotel room overnight. 3 wheels fit in the back seat (with the passenger seat forward) and one in the trunk
(305/30/20 and 305/30/19 tires on stock wheels fit snugly through the trunk opening, check to make sure your slick wheel/tire will fit beforehand). You can also get these wheel/tire carriers with handles to make loading and unloading the wheels easier: https://m.tirerack.com/accessories/t...duffels-4-pack
Old 04-16-2023, 10:08 PM   #7
Slurpee
Slurpee's Avatar
(305/30/20 and 305/30/19 tires on stock wheels fit snugly through the trunk opening, check to make sure your slick wheel/tire will fit beforehand.). You can also get these tire carriers with handles to make loading and unloading the wheels easier: https://m.tirerack.com/accessories/t...duffels-4-pack
I’ll have a follow car so won’t be a problem transporting them. If storing the slicks in the hotel room will be good enough to run them at high 30’s and 40’s, then I’ll do that.
Old 04-17-2023, 08:05 AM   #8
Msquared
Msquared's Avatar
Drives: Chevrolet SS 1LE
I have no real experience with these take-off slicks, but my guess is that if you can store them in the hotel room overnight so they don't see the coldest temps, then they'll be okay on track with a decent warm-up lap. I'm sure they won't crack or otherwise be damaged, so the only question is grip. Once you're driving on them, they generate their own heat...especially on a full-weight Camaro. Actual track surface temp will make a big difference in grip in this situation, so if the sun's out that would help a lot, too.
Matt Miller
2020 SS 1LE
Msquared is offline   Reply With Quote
Old 04-17-2023, 11:43 AM   #9
Slurpee
Slurpee's Avatar
With this cold weather, I have no problem using the whole first session to warm them up. Ambient temperatures will increase later in the day and track will warm up from other run groups. Thankfully Road America has plenty of straights to warm up the tires with brakes.
Old 04-17-2023, 11:49 AM   #10
That1guy_tim
That1guy_tim's Avatar
Drives: Camaro 1ss
were you at Autobahn this past Saturday?
That1guy_tim is offline   Reply With Quote
Old 04-17-2023, 12:45 PM   #11
Slurpee
Slurpee's Avatar
Yes!
Old 04-17-2023, 02:46 PM   #12
That1guy_tim
Drives: Camaro 1ss
Yes!
Thought so, I was the guy that came up and asked about your 18's (Nice to meet you)
Old 04-18-2023, 11:05 AM   #13
DylansZLE
DylansZLE's Avatar
Drives: 2022 Rapid Blue ZLE
I am in the same boat, I just got some Pirelli take offs and was worried about the cold temps for this weekend. A friend also told me to take at least two laps to warm the tires up.
2022 Rapid Blue ZL1 1LE order ZNWPCX
Ordered - April 8, 2021 // 2000 - July 30, 2021
3000 - August 3, 2021 // 3100 - August 6, 2021
TPW - August 30
3300 - August 21 // 3400 - August 21
3800 10/18 // 4150 Oct 22
6000 November 1st
Instagram: dylanszle
DylansZLE is offline   Reply With Quote
Old 04-18-2023, 01:19 PM   #14
Slurpee
Slurpee's Avatar
Great to meet you! Get that Camaro back together and back on track
