Old 04-14-2023, 02:12 PM   #1
Sephx1
Sephx1's Avatar
Drives: 18 ZLE, 18 SS1LE, 16 SS, 23 ZL1
Pump ethanol content
Since my ethanol and aux fuel kits are up and running, I went to the yellow pump and topped off the 50-60% blend already in the tank which was already half full. Tuner says safe to run up to 80%. Curious as to what the actual content was at the pump, I returned the following day with a 5 gallon jug in the back of my truck. When I tested it I found that it was not on the scale but probably around 50-60 percent straight from the pump. I figured it would be low as the pump only states that it’s above 50 percent. Will probably buy E85 by the drum from Sunoco or VP and mix my own at that ratio if it’s cheaper.
With the ethanol and no cats the exhaust smell is greatly reduced.
Might just leave the cats off.
Sephx1 is offline   Reply With Quote
Old 04-14-2023, 02:20 PM   #2
Z OH 6
Drives: 2024 CT5-V Blackwing
It varies depending on the station and sometimes even which part of the year. I've got three local E85 stations to me, all of them test at 80% or above year round.
$5.29 per gallon??? Wow that's expensive, its $3 per gallon here.
Old 04-14-2023, 05:05 PM   #3
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
Where I live our pumps have full e85 in the summer and around e50 in the winter. As of a couple days ago we are still on e50. I’m watching to see when it switches over to full e85.
CW3SF is offline   Reply With Quote
Old 04-14-2023, 06:00 PM   #4
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
In our area the E varies from 65% winter to E78-90 in the summer depending on which pump you go to. We have E stations everywhere...it's a beautiful thang!
Old 04-14-2023, 06:26 PM   #5
WiggyB
WiggyB's Avatar
Drives: 2022 Camaro 2SS 1LE
I topped off the other day and had to adjust my blend. Summer mix is in and seems to be sitting at 75% here in NC. At least where I'm at.
d1sc w/ stage 2 intercooler, Lt4 fueling, JMS BAP, lt2 intake, mamo ptb, kooks 1/78 longtube headers w/ h/f cats, alky meth kit, thpsi port injection
WiggyB is offline   Reply With Quote
Old 04-15-2023, 07:11 PM   #6
Chrome383Z
Chrome383Z's Avatar
Drives: 2019 Camaro 2SS
Yes it is! I have two within about 2 miles from my house lol.
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
Chrome383Z is offline   Reply With Quote
Old 04-15-2023, 08:33 PM   #7
Good for you guys, I have to drive 15 miles to the nearest gas station that sells E85. Still worth it
Old 04-22-2023, 09:22 AM   #8
CW3SF
CW3SF's Avatar
Filled up today and my local pumps had e80. Paid $1.859 per gallon
