![]() ![]() ![]() ![]() ![]() Drives: 2023 Chevrolet Camaro 2SS 1LE Join Date: Jan 2020
Jack stand placement (rear) question
Can I place the jack stand on the yellow highlighted portion below? I don’t have space to pull my jack stand to the left a little in order to place it directly on the pinch weld (which is what I read to use for the jack stands) due to my jack being in the way/wide. I wasn’t sure if whatever that piece is, can support the weight of the car. Any help is appreciated.
Long hauler
I wouldn’t try anything other than the pinch welds, there’s some plastics back there that can crumble iirc
2016 1LT v6 - Totaled Happiness: Infinite |
Thanks. I guess what I will have to do then is to uninstall my rear lift pads. Right now, it’s installed all the way to the right closest to the rear tire). If I remove them and install them all the way to the left, I’ll have space to put a jackstand to the right of it and not have to worry about whatever that metal piece is that I highlighted.
![]() Drives: Chevy Camaro Join Date: Jan 2022
I've been putting my jack stands over that bolt (not on the yellow like a pinch) to where the sides of the jack stand top touch either side of that bolt. No issues
There's an image on the forum somewhere with highlighted jack points
'22 2SS 1LE manual in Red Hot with Red seat belts, rotofab intake, catch can and everything amsoil.
Thanks. I just rewatched the lethal video where he shows where to put the stands and he also showed putting the stands over that bolt that’s parallel to the line I drew. When I watched it a few days ago, that made me nervous but after examining that area I think it’s fine and you also said you have not had any issues doing that. Glad I don’t have to remove my lift pads because I lock tighted them on a few years ago.
#6 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
You put a jack stand under that pinch weld and it'll fold right up. YOu would need a jack puck with a slot in it to make that work. Buy yourself a $30 set of jack pads off Amazon and install them. They work perfectly this. |
#7 | |
I actually bought rubber covers for the jack stand top with a slot built in it in order to avoid bending the pinch welds. |
