Old 03-30-2023, 03:36 PM   #1
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
2023 ZL1 DSX Flex Fuel kit with stock fuel system...
So is it even worth adding a Flex Fuel kit to a new ZL1 if your not also changing out the low side/high side fuel pump or injectors? What would stock allow, like e20? I'm contemplating not installing my DSX Flex Fuel kit if is will end up being a domino effect to other mods.... I'm mod'ed out at the moment ! (out of gas... no pun intended!)
Old 03-30-2023, 03:45 PM   #2
Z OH 6
Drives: 2024 CT5-V Blackwing
If the car is otherwise stock, you can use the stock fuel system and safely go to E50 without any issues.
Old 03-30-2023, 05:05 PM   #3
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
You've got headers / intake / throttle body at this point, right? (not counting exhaust since it really won't matter for purposes of this discussion)
If I'm not missing anything, I'll bet you could run e40 with your mods.
@KingLT1 could chime in with a more specific #.
Mods being installed-
Old 03-30-2023, 07:10 PM   #4
2023_ZL1-AUTO
Drives: 2023 ZL1
OK!
Old 03-30-2023, 08:29 PM   #5
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
If you go this route, you might want a JMS for insurance. I'm sure someone will add advice based on their experience.
Old 03-31-2023, 09:37 AM   #6
2023_ZL1-AUTO
Drives: 2023 ZL1
OK, so from what I'm finding, in most all cases, it looks like for a stock fuel system adding E, a JMS module is really kind of required? Looks like I will need to go that route. What happens if you end up mixing E10, E20, E30, E40 etc... then finally go past what your fuel system can handle (E-50), or is that not how it works? Would you need to siphon out and start over?
Old 03-31-2023, 10:02 AM   #7
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Your tuner will tell you the maximum e content. Then if you go over, just don't got WOT until you can adjust it back down. The fuel system can handle e100 if you are just putting around town.
Old 03-31-2023, 10:03 AM   #8
2023_ZL1-AUTO
Drives: 2023 ZL1
OK Got'cha! Thanks for the info !!!!
Old 03-31-2023, 11:21 AM   #9
Z OH 6
No. You wouldn't siphon it out, but if you're unable to dilute it by adding more 93 octane then you would just drive the car until you use some fuel and can add some 93 octane. You just wouldn't drive the car hard, you would drive it sensibly.
Old 03-31-2023, 12:33 PM   #10
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
The JMS booster is great for a bolt on car. You can see my mods in my sig below and with the JMS my limiting factor is still high side fuel. The JMS is doing great work for me. And I will second the recommendation to get KingLT1s input if possible. He’s very well versed in this area.
CW3SF is offline   Reply With Quote
Old 03-31-2023, 01:57 PM   #11
2023_ZL1-AUTO
Drives: 2023 ZL1
Thanks!
