Old 03-16-2023, 12:15 PM   #1
Pollock
LT4 M6
Pollock's Avatar
Drives: 2018 ZL1 1LE
E2 Catch can on the road course.
Is this specific catch can working for you? Mine fills up before the 30 minute session at NCM is over. Curious what others are doing.
I have the inlet going to the center port on can. One exit goes to intake tube. Other exit goes to vacuum line. Check valves pointed away from can.
Mods
Ported Blower
Kooks headers
NW 103 TB
Rotofab big gulp.
Pollock is offline   Reply With Quote
Old 03-16-2023, 12:27 PM   #2
Pollock
LT4 M6
Pollock's Avatar
Elite just sent me directions. Wish I had those at time of install. Directions say to transfer O rings from stock PVC valve to their diverter. Pretty sure I didn't do that. Didn't know at the time.
Old 03-16-2023, 12:31 PM   #3
willzilla
D3RPZILLA
willzilla's Avatar
Drives: 2021 Camaro ZL1 a10
That sounds like how I have mine configured:
Also did a quick overview video of everything:
I run the E2-X Ultra can version.
Which one do you run? Have a photo?
I don't road course but do a lot of regular driving mixed in with hard driving and it doesn't fill up crazy or anything.
Website: z1lla.com | YouTube: sub.z1lla.com | Merch: Shop & Etsy
YouTube Playlists: Performance Mods | Show Mods | Other Mods
willzilla is offline   Reply With Quote
Old 03-16-2023, 12:33 PM   #4
willzilla
D3RPZILLA
willzilla's Avatar
Just saw you wrote this as I was writing my post, lol.
But yeah, def need the O-rings on the PVC valve diverter. Seems obvious when looking at it so maybe you did so and just don't recall?
Old 03-16-2023, 12:41 PM   #5
Pollock
LT4 M6
Pollock's Avatar
I used your video as a reference for install. Mines hooked up the same. Even bought the quick disconnect fittings. I don't have a picture handy.
I didn't get any oil from the dyno or thrashing the car up and down the highway. I am thinking the extreme g forces on the road course cause the oil to pool and get sucked in. But that's just a theory.
Looking at the directions they sent me, the diverter had the o rings already installed. lol. I am taking it off in a few days. I will find out if I have O rings or not.
Old 03-16-2023, 01:37 PM   #6
willzilla
D3RPZILLA
willzilla's Avatar
Ok... good luck! Is it the Ultra can?
I also noticed on their website it appears they sell quick connectors directly now, lol
It also looks like they sell a "restrictor" maybe something like that would help.
Once you double check O rings in place (they probably are), you can see what Elite recommends from there.
Old 03-16-2023, 02:24 PM   #7
ZX-10R
ZX-10R's Avatar
Drives: 2019 ZL1 Riverside
Love that Ultra can - best in the industry imo
You're getting more blowby (and you're getting ALOT) because you're on boost most of the time on track, I don't get the "oil to pool" comment - pool where? The can is supposed to keep oil out of your intake manifold
ZX-10R is offline   Reply With Quote
Old 03-16-2023, 02:31 PM   #8
JSH
JSH's Avatar
Drives: '20 ZLE
Given that the OP inquiry is about the E2 can, I'll just say that in two years my can has never had a teaspoon of oil in it.
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO.
15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR.
100 octane: 1045hp/1055tq.
100 octane + Alky MAF Meth (1) 10+:
Old 03-16-2023, 02:36 PM   #9
SJFGTO
Oh Oh it's Friday Night!
SJFGTO's Avatar
Drives: 2018 ZL1 1LE Nightfall Gray
E2 can here as well. Maybe two teaspoons tops every 3000 mile oil change.
Four that wanna own me
Two that wanna stone me
One says she's a friend of mine...
SJFGTO is offline   Reply With Quote
Old 03-16-2023, 03:00 PM   #10
Pollock
LT4 M6
Pollock's Avatar
I was just speculating. I am far from a expert on this issue.
And to the others. I get minimal oil from driving on the street. It's on track when car is typically above 3500 rpm the entire time.
Old 03-16-2023, 05:04 PM   #11
ZX-10R
ZX-10R's Avatar
Extended time on boost = more blowby
GM engines aren't exactly known for excellent ring sealing - they may be one of the worst? I'm not knocking GM it's just an all too common problem
Imagine running this motor at 24 psi like the M5 or RS3 - it would be ugly. Too bad because the power potential would be impressive (and still is with some modded cars)
Old 03-16-2023, 05:35 PM   #12
Chippy
BanHamWatch
Chippy's Avatar
Drives: 21 ZL1 1LE
Track use = lots of blow by. I can attest to the difference from street to the track has a significant difference. My auto keeps the rpm’s high the whole time I’m tracking as well as a lot of engine breaking so blow by is high.
2021 ZL1 1LE
Auto
Chippy is offline   Reply With Quote
Old 03-16-2023, 06:07 PM   #13
20Bluezl1
I have the Ultra can and it flaws and I do multiple track days without draining.
Old 03-20-2023, 12:46 PM   #14
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
OP, it’s warmer here in TX so I run 15/50 all the time. When running 0-40 the can would fill up nearly every session. Now I can go the whole day without it filling up.
