Old 03-01-2023, 11:35 AM   #1
hms2488485
hms2488485's Avatar
Drives: '17 Camaro SS 1LE
Trailer Light Harness
Does anyone have a video or a tutorial on how to wire up a trailer light wiring harness? I recently added a hitch receiver and purchased a small trailer for track days and would like to add the wiring harness for trailer lights, without screwing anything up. I purchased the CURT hitch receiver and the CURT wiring harness.
Thanks in advance!
hms2488485 is offline   Reply With Quote
Old 03-02-2023, 07:00 PM   #2
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
No video...........sorry, but the pdf is generic wiring instructions. use '3 wire'
I used a Hopkins 46255 powered converter
pull the rear hard panel and the two side soft panels out of the trunk
Vehicle wiring type: "3-wire"
left turn signal: Car-Blue/White stripe (Converter-yellow)
running light: Car-Purple/White stripe (Converter-brown)
right turn signal: Car-Blue/Violet stripe (Converter-green)
no need for a brake signal
I got 12v from one of the BATT terminals in the trunk and there are several ground lugs nearby.
I used crimp-on insulated snap locks
It is handy to have a light tester like this one, they are available at walmart and most auto parts stores.
https://www.amazon.com/Oyviny-Traile...%2C173&sr=1-26
