Old 02-10-2023, 08:45 PM   #1
Sillysspeed
Drives: 22 LT1
Made a few passes…
On the way home from the grocery store.
*Passes made on vacant road in Mexico*
Procharger P1x stock pulley. Mostly around 6psi thru run. Hard tires aired down to 25psi. E48, just below full tank of fuel. Car is stock engine/stock exhaust. Car is lt1 10speed.
Spun hard 1st pass, forgot to air down from 35psi lol
2nd pass 10.95
3rd pass dragy slid off dash
4th pass in photo
No cool down just round robin street car stuff
Sillysspeed is offline   Reply With Quote
Old 02-10-2023, 10:16 PM   #2
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Nice run! Congrats!
Old 02-11-2023, 07:51 AM   #3
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Good pull! That's some prime air!
Old 02-11-2023, 09:54 AM   #4
Sillysspeed
Drives: 22 LT1
Definitely! Only good thing about warmer weather is the traction would be more ideal. I do have some 305-45r17 to put on. Should get in the 1.6x 60ft or maybe better
Old 02-11-2023, 09:59 AM   #5
jlaudio11
jlaudio11's Avatar
Drives: Chevy Camaro
Nice run! I'm impressed the hard tires worked that well. What was the launch technique and did you try different ways?
'20 Camaro LT1
Twin 67/62 turbo 401(L8t) Texas speed forged piston & rod, BTR stg1 turbo cam, holley ultra lo, port injection, circle d 3600 stall, et street r’s on racestar recluse wheels.
1.33 3.75 5.75@122.98 1/8 pb 9.04@141 1/4 pb technically
'94 Camaro Z28 6mt cc306 cam, 4:10's, longtubes with x pipe, otr intake
jlaudio11 is offline   Reply With Quote
Old 02-11-2023, 05:25 PM   #6
Sillysspeed
Drives: 22 LT1
I’ve posted up a couple dragys on the same road when the car was lt2 intake and drop in k&n. No tune. Went a bunch of 11.6x’s. The tires work really well aired down to 24-25psi and heat them up good.
The road I test on has some rubber down from people racing there. It’s not great but it definitely helps especially with the hard tires. I just do a burnout then back up into the tracks. Then off we go. I got it where I could pretty much dead hook the car on motor. That’s how I was able to get those sweet 60 foots for stock car. With the Procharger it was a little tricky. They haven’t been out there it looks like lately. A lot less rubber but I was able to feather it out and then mash it quickly. Got some wheelspeed and some chatter with the tires fighting for traction. I was pretty happy with 1.74 60ft with the Procharger. Probably can do better in the summer. Tires are 285/35r20 potenza re-71rs Expensive but they are badazz for a hard tire.
Old 02-15-2023, 06:40 PM   #7
red6.2
Drives: 2010 camaro
nice setup! I'm sure your happy with it.
red6.2 is offline   Reply With Quote
Old 02-15-2023, 08:27 PM   #8
ZO6Ted
Old badass
ZO6Ted's Avatar
Drives: 14GMC 2.9 16GMC Turbos 2020Silv.6.2
Very impressive. Congrats!
I've had 7 Camaro's. All gone...for now.
Current build in progress 2016 GMC4x4 RCSB twin hair dryers ~1k whp fbe port inj 1/8 mi & stealth street terror
ZO6Ted is offline   Reply With Quote
Old 02-16-2023, 06:34 PM   #9
Sillysspeed
Drives: 22 LT1
Thanks! Kinda sorta lol. Wouldn’t mind a little more
Old 04-08-2023, 09:04 PM   #10
Sillysspeed
Drives: 22 LT1
Made a pass this afternoon with the et street r’s. Did some funny stuff up top, didn’t have the mph. Only one pass
