![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Turbo LS3 Join Date: Dec 2009
Spline Count on Outer CV
Does anyone know what the spline count is on the outers going into the rear hub? Any difference between the SS and ZL1 hubs?
2010 SS - Kind of an On3 kit, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1 brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. Gen6 ZL1 brakes. |
Geoff
Drives: 2022 SS 1LE Join Date: May 2013
Cracka, are you running a 5th gen? If so, go with the Z28 hubs. They're the same spline count as the SS and SS1LE. Not sure about the ZL1 hubs.......I seem to recall that they're different.
Thanks Geoff, I do run fifth gens and both have the ZL1/Z28 hubs with long studs. What I am really after is to try to figure out if Gen6 ZL1 outer CVs are the same as GenV ZL1 outers. They look very similar, but before I drop $100+ on ebay to see if I can make it work, I was hoping I could get a little more confidence by confirming Gen6 ZL1 axles are 32 splines going into the hub. The Gen5 ZL1 axles are 32 splines into the hub and 41 splines into the CV for the outers. I know a lot of people look at some of the mods I try as being cheap, but these parts are disappearing fast so those of us who will hang on to these cars will need to get creative. Unfortunately, the aftermarket is so full of cheap Chinese axles that there is nothing to restore the factory OEM axles. If you don't run it hard, you buy crap axles and if you do, your kids have to go to community college so you can afford a driveline that will hold up.
Geoff
I had my hubs off the other day, I did not count splines or take a pic. Sorry mate, I’m no help.
![]() Drives: '16 2SS M6 Join Date: Aug 2019
Hubs are the same part number between 6th gen SS/ZL1 13542186
David
'16 2SS M6 black on black, SW long tube full exhaust, NPP, Roto-fab CAI, ported stock TB '16 2SS M6 black w/Metallic black stripes, Kalahari, 6 piston front (totaled 1/22/20) '14 Fusion Titanium 2.0T '83 Jeep Wagoneer |
Gen6 hubs take a 33 spline axle same as Gen5s. In fact, MOOG hub pn 512663 is sold to fit all Camaros between 2010 and 2019. I confirmed this with Moog tech support.
The Gen6 axle going into the outer CV is approximately 32mm with 30 spines. It is slightly smaller <1mm than the Gen5 RH axle.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. Gen6 ZL1 brakes. Last edited by CamaroCracka; 02-02-2023 at 02:02 PM. |
