Question about oil?
Instead of using 0/40 weight oil, has anyone
Used A 5/40 weight oil instead,on the newer LT4 motor? |
![]() ![]() ![]() Drives: 1969 Z28,1992 Z28,1994 Z28,1999 SS Join Date: Oct 2021
Just use what GM recommends.
23 ZLE Rapid Blue, M6. 6/27/22 TPW. Off assembly line on July 12th, 2022. To Dealer August 6th. Delivered August 8th. 129 miles. 99 SS Vert, Hugger Orange, A4, 806 miles 94 Z28, Black, M6, 595 miles 92 Z28, last car built at Van Nuys Plant, Red, A4, 125 miles www.last1992camaro.com 69 Z28, Dusk Blue, M4 29 Ford Business Coupe 28 Ford Pickup 24 GMC Denali 2500HD CCSB 4x4 22 Jeep Grand Cherokee 13 Ford F150 Crew Cab 4x4 |
![]() Drives: 2018 ZL1 Coupe NFG M6 Join Date: May 2017
I've used the 0-40 recommended oil for the past two track seasons and gotten an oil analysis after each season. Based on a favorable analysis I see ZERO reason to make a change unless you're going to try to be a cheap ass and use Shell Rotella T6...
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School 2017 Colorado Z71 <- Daily 2018 ZL1 M6 <- Not Daily |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
i use 5w40 torco sr1 in my lt1
I’m talking about weight , not manufacture,
I was considering 5/40 for summer because It’s usually 90-100 degrees!. I’d stick with 0-40 during “Winter “. |
Why try to outguess the engineers? They have way more knowledge about engines and oil, than anyone on this site.
#7 |
![]() ![]() ![]() ![]() Drives: 2018 ZLE Join Date: Feb 2018
#8 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
Excellent article in the current issue of HR. Definitely stick with what your manual calls out for.
#9 |
![]() Drives: ´18 ZL1 A10 Red Hot 😍 Join Date: Jan 2016
Red Line 5w40 Full Synthetic here, but catless…
If you maintain cats don’t go away from a Dexos2 oil.
First ZL1 in Spain (Madrid)! Red Hot, A10, PDR, carbon fiber hood & grounds effects...
![]() Last edited by Akura; 12-14-2022 at 07:18 AM. |
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
Stick with the manufacturers recommendation! I use full synthetic Lucas 5w30 in mine year round.
#11 | |
Aww, yet another oil thread with almost the same question in the OP
![]() Quote:
What is also true, however, is that they are always forced into a tradeoff with different weights assigned to different parameters (cost, maintenance intervals, engine life, fuel dilution, blowby, carbon deposits and probably a hundred more), so their solution may not be the perfect one for an enthusiast with different priorities. All in all they have both the advantage of in-depth knowledge/data and the disadvantage of working for a giant money making machine that never allows them to tell the truth and forces them into cost cutting compromises, which gives a valid reason for all these discussions and alternatives to exist.
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 Last edited by arpad_m; 12-13-2022 at 08:55 PM. |
#12 | |
PKG4U
2020 Camaro LT1. Bought 10/2020 | GM PERF. CAI | GM Muffler Delete (Performance Exhaust 4” tips). | SOLD 1/2022|
2018 ZL1 Summit White | Bought 1/2022 | PDR, Recaros, Carbon Dash, WeaponX Hx System, Apex SM-10 in ZLE fitment w/PS4S Mods after Warranty “Imma keep it stock” ![]() |
#13 | |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 2SS A8 Join Date: May 2019
![]() You like oil threads way too much. ![]() https://www.camaro6.com/forums/showp...2&postcount=70
#14 |
What can I say, I should probably be asleep already
