Jacking points?
Using just one floor jack, where are the recommended
Jack points on ZL1, to lift the twofront wheels,and the two rear Wheels? Thx |
![]() ![]() ![]() Drives: 2017 1SS 1LE Join Date: Jun 2016
https://www.camaro6.com/forums/showp...79&postcount=5
All points highlighted in yellow on this post. Recommended to use a jack on the "middle" point to lift the whole side of the car then put jack stands on the front and rear then repeat on the opposite side.
2017 SS 1LE.
Thank you Al Oppenheiser!
I don’t wish to use sill Jack points, just rear middle Jack points
And front middle jack point ( it’s a convertible) if that makes A difference? |
On the vert, you have the X-brace that occupies two of the three green locations in the above pic. But you can jack the car at the available pinch weld slot just next to the front X-brace bracket. Put the jack stand(s) under the X-brace brackets. They're quite stout.
Is there a Jack point on front of car that I can use
One floor jack to lift both front wheels?? |
#7 |
I never use the jack points. I you notice on the front brace there is a bolt just in front of the jacking point on the picture, that's where I put my little aluminum floor jack. Then there is a brace in the rear just inside the jacking points and in the rear I slide my floor jack under the spring coil spring perch and that way it jacks up much quick and your not lifting the whole side of the car up. When I'm switching out to my drag pack I use two of the small jack and lift just the rear to swap out to the slicks and then go to each side for the front.
#8 |
#9 |
Thx gunkk, I figured as much, although I’ve seen YouTube vids of
Techs using “front brace”? To lift the two front wheels at the same Time??!! |
#10 | |
Just do one side at a time. It only takes a minute.
#11 | |
![]() ![]() ![]() ![]() ![]() Drives: 2023 CT5 Blackwing, 2025 C8 Z07 Join Date: Sep 2016
There is zero risk using the pinch weld jack points. That's what they are designed for. Just get a quality lift pad or puck. ZL1addons or the QuickJack pads.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 2025 Hysteria Purple C8 Z07 |
#12 |
![]() Drives: 2020 Chevy Camaro ZLE Join Date: Jan 2023
I use a cheap pinch weld puck I bought off Amazon and it works great! Get 4 pinch weld jack stand adaptors too. They come in handy.
#13 |
2020 Shadow Gray 2SS
I don't have a ZL1, but the jacking points should be the same as an SS...
Hope this helps someone!
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF-Full Front & Rockers, 35% Tint, CeramicPro coated, RST Stainless Brake Lines, Castrol SRF, MSD Plug Wires, Mamo V3 Ported TB Left: My "fun" ride (455 HP). Right: My "work" ride (52,000 HP): a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph. BOTH AWESOME to operate... |
#14 |
2SS, I have the same lift, it’s a PIA to set up
But works great, I use the rubber pads that It came with, didn’t realize there’s enough Room in the garage to lift car without hood Hitting ceiling |
