Old 10-04-2022, 08:36 AM   #1
adamjwilson
Drives: 2022 Camaro 2SS A10
Oil Catch Can
Is an aftermarket oil catch can a necessity for the V8 Camaros? What brand do you recommend? I basically understand the concept of one, so why doesn't GM make this a standard feature (besides the $$$ issue)? Thanks for any comments/responses
adamjwilson is offline   Reply With Quote
Old 10-04-2022, 08:46 AM   #2
dmcmahan60
dmcmahan60's Avatar
Drives: 2017 SS
Welcome aboard and with a little searching there are many threads on this subject I run the Mishimoto on mine and bekieve it helps. But it is your car, and your decision
https://www.camaro6.com/forums/showt...ght=catch+cans
dmcmahan60 is offline   Reply With Quote
Old 10-04-2022, 08:47 AM   #3
ZPirate
ZPirate's Avatar
I wouldn't say that a catch can is a necessity, although lots of folks have them. The way I look at it is that it can't hurt. And its a pretty easy install. I have a Mishimoto catch can on my 1LE. My Camaro is the third car I've installed a Mishimoto oil catch can on. Excellent quality product.
2003 Nissan 350Z (modified)
2009 BMW 135i (Sold)
Old 10-04-2022, 08:54 AM   #4
adamjwilson
Thanks for the response
Old 10-04-2022, 09:10 AM   #5
ZPirate
ZPirate's Avatar
Here is a post install picture.
Old 10-04-2022, 09:16 AM   #6
Slippy
Drives: 22 1LE
Mishimoto is nice but the can volume is relatively small. I had a Mishimoto on a LS3 car, I went with UPR for this car.
https://www.uprproducts.com/16-21-ca...r-plug-n-play/
Slippy is offline   Reply With Quote
Old 10-04-2022, 09:20 AM   #7
adamjwilson
Too bad they discontinued the color hoses... that looked pretty sweet!
Old 10-04-2022, 05:06 PM   #8
ZPirate
ZPirate's Avatar
If you have to worry about the volume of oil blow by being more than what the catch can will hold, then the engine likely has other issues. I recommend dumping the catch can at each oil change.
Old 10-04-2022, 06:56 PM   #9
Invertalon
Drives: 2021 2SS
No, not required or needed.
If the engine needed that type of device it would have one already.
Invertalon is offline   Reply With Quote
Old 10-04-2022, 07:09 PM   #10
Slippy
Drives: 22 1LE
Those in cooler climates may want to check smaller cans more frequently due to condensation.
https://www.camaro6.com/forums/showp...8&postcount=25
Old 10-04-2022, 10:41 PM   #11
keep_hope_alive
Electrical Engineer
keep_hope_alive's Avatar
Drives: 2023 1SS A10 Black
Thanks for the discussion. I'm sold. Will go with the E2.
Daily Driver mileage update: 45k mi. @ Mar 2025
Old 10-05-2022, 06:47 AM   #12
dmcmahan60
dmcmahan60's Avatar
Drives: 2017 SS
I dump mine at every oil change and have never had a problem of it being overfull. And I commute 65 Plus miles a day 5 days a week.
Old 10-05-2022, 08:54 AM   #13
jamala00
jamala00's Avatar
Drives: 2016 Camaro 2SS Hyper Blue Metallic
^^^ This
jamala00 is offline   Reply With Quote
Old 10-05-2022, 11:39 AM   #14
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
I’m not a catch can believer, at least for the stock set up and normal driving. With that said, I know you’re going to drive your car as much as you can in the winter. Just a heads up that having a can is a major pain in the neck, as there’s way more condensate and it will freeze once the engine is shut down. I haven’t experienced this myself… but if I remember correctly, another member installed one and ended up pulling it off (drives all year long, including winter). Just something to think about… good luck either way.
