Old 09-24-2022, 11:59 AM   #1
Redwings1
Drives: 23 ZL1, 22 C8 Sold. 21 LT1 Sold
Catch cans on LT-4
I just purchased a catch can from ADD-W1. For install you have to take the supercharger apart. I'm pretty mechanical, I don't think I want to take my supercharger off to install the catch can. Are there other cans that you don't have to disassemble the supercharger? Thanks Steve
By the way quality is 1st class on this product.
Redwings1 is offline   Reply With Quote
Old 09-24-2022, 12:13 PM   #2
JSH
JSH's Avatar
Drives: '20 ZLE
Look at Mighty Mouse
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 09-24-2022, 01:48 PM   #3
Firecaptain
Firecaptain's Avatar
Drives: '22 Summit White ZL1 A10
Pretty sure you have to at least raise it up to get to the crankcase vent for any of them
2022 ZL1 Summit White A10
2020 GT350 Heritage Edition-Chassis L0350
2019 ZL1 Summit White M6
2018 Hellcat White Knuckle M6
2016 Hellcat GoMango A8
2002 Dodge Viper Viper Red
2002 Corvette Z06 Millennium Yellow
1998 Dodge Viper Viper Silver Metallic
Firecaptain is offline   Reply With Quote
Old 09-25-2022, 09:35 AM   #4
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
This, and make sure you have a few extra SC bolts available, because it's very easy to break them, particularly the ones near the firewall. I'm sure there are a few forum members with extras
Old 09-25-2022, 10:59 AM   #5
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
Buy the replacement kit which comes with the gaskets and bolts. The bolts are stretch, single use.
wakespeak is offline   Reply With Quote
Old 09-25-2022, 11:40 AM   #6
JSH
JSH's Avatar
Drives: '20 ZLE
Yea, you have to remove the blower or at least lift the front
2020 ZL1LE A10.
Old 11-13-2022, 08:52 PM   #7
Knarfluna
Drives: 2022 Camaro ZL1
Something about breaking the seal on the intakes and expect that seal to do its job when you go back and set it back in place….gaskets …to me, seem like one use only
Knarfluna is offline   Reply With Quote
Old 11-14-2022, 08:25 AM   #8
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Yes, you need to raise / remove the blower...
Not hard, a little messy, use this Super Charger Bolt Kit #12679527
And be prepared to burp the coolant system. If it were me, id add an expansion tank at the same time.
Old 11-14-2022, 10:14 AM   #9
45LongColt
45LongColt's Avatar
Drives: 2018 Zl1 Camaro
Socal, thats probably the best looking engine Ive seen. What heads, valve covers, coil packs and relocation kit do you have?
Redwing, I also have the MightyMouse Wild Catch Can and expansion tank, but mine is mounted off shock tower brace area.
45LongColt is offline   Reply With Quote
Old 11-14-2022, 12:50 PM   #10
SOCAL.M6.ZLE
Thank you sir... Buid Thread is here...
https://www.camaro6.com/forums/showthread.php?t=609588
Valve Covers, and Coil Relocation Kit by KATECH.
Old 11-14-2022, 01:18 PM   #11
AZIROC
Drives: '86 IROC-Z '18 ZL1
Got a question for those that have one.
I just got a MM wild can installed when I did a pulley upgrade. tthey did a great job on the install. My question is, is there a way to visually check the can and if there is anything in there? Like can I take the vent on the top off? Or is the only option to just open the drain valve and see what comes out.
Old 11-14-2022, 01:29 PM   #12
Mark R
Drives: 2018 ZL-1
Not really. They are very squishy and soft and rest in grooves. Assuming one is doing it on a fairly new engine, you are just lifting the front of the blower a couple of inches, then setting it back down after changing out the PCV valve.
I was super paranoid about the possibility of pinching or moving one of them, but in practice, it was easy.
Old 11-14-2022, 01:44 PM   #13
ZX-10R
ZX-10R's Avatar
Drives: 2019 ZL1 Riverside
If anyone needs the bolt and gasket set let me know (PM)
ZX-10R is offline   Reply With Quote
Old 11-15-2022, 07:10 AM   #14
cjperformance
cjperformance's Avatar
There is a sight glass on the side. Empty when you observe fluid appearing in the sight glass.
DSX Aux Low Side | LT4 high side | Flex Fuel
TooHighPsi Port Injection (installed & tuning)
CircleD 3K Stall | QA1 CF Driveshaft
Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear
Forgestar F14 18x8 NT555G2 235/50/18 Front
10.84@131 w/4.13" pulley
??.??@??? w/3.7" pulley (installed & tuning)
