Old 09-15-2022, 02:30 PM   #1
ZapperZ
Drives: 2018 ZL1 1LE 2022 GMC AT4 HD
Which Gates Green Belt on stock pulley ?
Want to switch out the OEM blower belt for a Gates Green Micro-V belt with stock pulleys
I want to be sure to have the correct part number
ZapperZ is offline   Reply With Quote
Old 09-15-2022, 03:12 PM   #2
gotswap
gotswap's Avatar
Drives: 2019 ZL1 Crush
the stock length one
2019 Crush A10
E-Force 2650
670WHP 615WTQ
All besides the 2650 is bone stock down to the air filter.
gotswap is offline   Reply With Quote
Old 09-15-2022, 07:20 PM   #3
ZapperZ
I was hoping for someone who's gone to a Gates green belt and had a part number
Old 09-15-2022, 07:38 PM   #4
RamAir02
Shadow Gray '19 ZLE M6
RamAir02's Avatar
Drives: '19 ZL1 1LE M6
Stock ZL1 Belt is 82.87" 8 rib
The Gates belt part number is K080828. It looks like it only comes in the RPM Micro-V. I can't find the Green equivalent.
https://www.gates.com/us/en/search.h...&text=K080828+
YouTube
Old 09-16-2022, 06:50 AM   #5
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
The RPM belt is a stronger but stiffer belt (than the green belt, which as you said isn’t available in our stock size). I’m running the RPM on stock pulley sizes. It works great.
CW3SF is offline   Reply With Quote
Old 09-16-2022, 10:00 AM   #6
Tay
Drives: 1985 Oldsmobuick
Are you running the green belt for extra security?
Side question, would running the stock size Griptec pulley be mod worth doing and can you run the green belt with that for extra extra security?
Tay is offline   Reply With Quote
Old 09-16-2022, 10:23 AM   #7
rls61
K080825HD
It's 3/8 in. smaller but works fine on the stock tensioner
rls61 is offline   Reply With Quote
Old 09-16-2022, 11:28 AM   #8
ZapperZ
Originally Posted by rls61 View Post
K080825HD
Thanks that's what I'm looking for!
I know the Green belt isn't listed for the ZL1 LT4 that's why I asked
Old 09-16-2022, 05:13 PM   #9
CW3SF
CW3SF's Avatar
See above. I’m running the RPM belt.
Old 09-17-2022, 11:54 AM   #10
F1rob
F1rob's Avatar
Drives: 20 ZL1 Conv, 2023 SR Z51, 69 Vette
Sorry for the dumb question, but why swap the belt?
Rob
Current
2020 ZL1 Conv 6M
2023 Stingray HTC Z51
2025 Explorer ST
1969 Corvette Conv 427 Tri Power 4M
2020 Cadillac CT5
2009 G8 GT
Recent Past
1969 SS/RS Conv Pace Car 350/350
2000 Camaro SS Conv 6M
2005 C6 Conv 4A
1998 C5 Conv 4A
F1rob is offline   Reply With Quote
Old 09-17-2022, 01:20 PM   #11
CW3SF
CW3SF's Avatar
Rob
I wanted the stronger belt (RPM) when I re-installed my Kong ported supercharger. I think some people just want the green belt because it looks cool.
Old 09-18-2022, 05:16 PM   #12
ZapperZ
I like stuff that looks cool too
All I asked for info pertaining to the Green Belt...
Old 09-18-2022, 05:24 PM   #13
ZapperZ
Door panels cut out...
Old 09-18-2022, 07:28 PM   #14
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
No actually the rpm belts are known for slipping which is why most , rather pretty much all Shops use the micro v green belt.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
