![]() Drives: 2017 Chevrolet Camaro ZL1 M6 Join Date: Jul 2020
DSX low side installed. First impressions.
I had the JMS pushing my low side fuel pump for the 125 Flex Fuel mod from Ted. After the Maggie/cam mod, it wasn't enough.
Installation went smooth and here is what I have now. At 6500rpm on e50, I am getting commanded fuel pressure, low and high, with 28 degrees timing and 14.69 psi of boost. IPWs are 5.11ms. I am curious if she will run e60? And, if the 10% will outweigh the risk?
JRE Terminator Rough Idle Cam
Magnuson 2650 - 15% lower, 90mm upper FIC+30% DSX Flex fuel/Low side NW 103mm TB/Roto-Fab CAI Monster S Series Elite E2-X 2" TSP LT's BMR:BK063, BK060,TCA061, UTCA060, UTCA063 Weld Beadlocks/17" NT5R2 |
![]() Drives: 2024 ZL1 M6 Join Date: Sep 2018
With it holding commmanded and the inj pulse width good, I bet it will take E60 no issue. E50-E60 is the sweet spot and works well on these fuel limited systems.
2024 Riverside Blue ZL1 M6
Magnuson 2650R, NW 103, Roto Fab Big Gulp Kooks 2 inch LT's, Stainless Works Legend NPP THP Billet Valve Covers, Mighty Mouse Wild CC Signature Forged 20x10.5/20x11.5, BMR springs, BMR Cradle lockout, AAD Billet arms 2023 Vivid Orange ZL1 M6 - sold 2019 Riverside Blue ZL1 A10 - sold |
We will find out.
Moderator
28 degrees of timing on E50 sounds like a LOT…? I would have expected 22-23…
![]() Drives: Chevrolet Camaro Join Date: Apr 2022
28 degrees is a ton more than I'm running, although you're 1.5 points lower compression and blending ethanol. Am I just baby soft at 15 degrees on 93 at 10 psi?
Procharger P1X, CSP Big Boy Cam, CSP Headers, LT5 Throttle Body, MSD Intake, LT4 HPFP, LT4 Injectors, JMS BAP, 93 + Boostane - 750+WHP
#6 | |
![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL1 Join Date: Mar 2019
Your already at max timing Martin I know you want to keep running E60, but your timing is already very high for E50. Plus ted never removed the adders for PE/COT so its got even more timing adding into it. It will take it, but I highly doubt your making anymore power.I told you the JMS wasn't enough
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
#7 |
I am seeing no KR but, you are not the only smart fella that has mentioned that. I think I'll shoot Ted a note. But, if that is too much, shouldn't it show somewhere?
#8 | |
![]() Do you think I should limit the timing? I am not looking for .001's.
#9 |
Former GM Technician
Drives: 2018 ZL1 A10, 06 Silverado Duramax Join Date: Sep 2009
I was seeing the same on my friends car that Ted just tuned.
I asked him if the 28° is not too much for his car running top speed on the German Autobahn. Ted answered that E requires alot of timing.
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, DSX dual intank pump, Lingenfelter high flow check valve, Motion Raceworks Flex Fuel adapter, LPE Big Bore Hpfp, XDI 30% Injectors, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: SwissZL1 |
#10 |
Just sent Ted an email. His first question was low side pressure: 72psi. I'm awaiting a reply.
#11 |
Thank you Al Oppenheiser!
#12 |
#13 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
Ted like to run more timing than most on e85, for what it's worth. To the tune of like 4 to 5 degrees, typically. To me, on e85: when it stops making more power, stop adding timing, then drop a degree out of it and call it a day.
Also, you won't SEE knock retard on E, even if knock is present. You can run timing high enough to get yourself into trouble. That said, Ted has a LOT of these cars out there, so if he's comfy at 28 degrees, I wouldn't sweat it. Does the car ever actually SEE 28 degrees in a log? It may just be 28 in the main high octane table, but the adders pull it down.
Mods being installed- oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc. |
#14 | |
Ted's response to my query about the timing was, "what about it?" My response was, "All the "fellas" say it is excessive." His response, "All the "fellas" are not professionals." Gotta love him. I have not heard one negative comment about him. I was more concerned that I may have done something to upset his tune. I will settle at e50 (yes, Mike ) and call it a day.
