Old 08-16-2022, 08:50 AM   #1
JVMC
Drives: chevrolet camaro
illuminated Bow Tie on 2022 SS
Has anyone installed the Illuminated bow tie on a 2022 SS. part # 84329529. After peeling back the liner, I cannot find the matching connector in the wheel well and the installation diagram does not match the layout behind my DRL. The image below is slightly off as the ballast is mounted 45 degrees clockwise with the connector on the left. It is not a match for my harness.
JVMC is offline   Reply With Quote
Old 08-18-2022, 02:57 PM   #2
Zapote21
Tampa Bay Camaros
Zapote21's Avatar
Drives: 2017 Krypton Green 2SS
I did a post on the bow tie on my 2020 2SS, but sadly I just looked and I dont have a pic of the connector. I dont imagine it is much different than a 22. Its attached to a metal beam behind the headlight.
https://www.camaro6.com/forums/showthread.php?t=576703
Me and wife, in order
2011 2SS SGM
2013 2SS Hot wheels vert
2016 C7 DSOM
2012 2SS yellow vert
2017 2LT Krypton Green
2018 2LT Hot wheels crush
2020 2SS Shock vert.
2017 2SS Krypton Green coupe
Zapote21 is offline   Reply With Quote
Old 08-19-2022, 10:17 AM   #3
6camaro1le
6camaro1le's Avatar
Drives: Rapid Blue 2SS1LE
I just had same issue on my 22. The instructions GM provides are for 16 through 18. 19 through 22 its on the driver's side on metal frame right above the silver square thing.
6camaro1le is offline   Reply With Quote
