Tampa Bay Camaros
Drives: 2017 Krypton Green 2SS Join Date: Jul 2011
Illuminated bowtie 2020 SS
So I bought the kit, part #84329529, which is supposed to fit the 2020 SS. Has anyone else tried it?
Tried to install today, but the stock bracket doesnt fit the illuminated bow tie. It appears to be the right kit from looking at harness. Its dfferent from the 16-18. Also different part# Sent from my SM-T860 using Tapatalk
Me and wife, in order
2011 2SS SGM 2013 2SS Hot wheels vert 2016 C7 DSOM 2012 2SS yellow vert 2017 2LT Krypton Green 2018 2LT Hot wheels crush 2020 2SS Shock vert. 2017 2SS Krypton Green coupe Last edited by Zapote21; 06-07-2020 at 06:30 PM. |
Tampa Bay Camaros
Anyone?
2011 2SS SGM 2013 2SS Hot wheels vert 2016 C7 DSOM 2012 2SS yellow vert 2017 2LT Krypton Green 2018 2LT Hot wheels crush 2020 2SS Shock vert. 2017 2SS Krypton Green coupe |
Tampa Bay Camaros
Update... According to the install instructions at the dealer, you have to drill a hole in the stock bracket for the connector to ft through it. Although there is still the issue of the grille... More to come
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
Subscribed. I was thinking about doing this mod.
Tampa Bay Camaros
I have been discussing with my dealer. There is no other bracket, so the stock one is it. I ordered a new one, but its 3 weeks out. Will keep updating
Tampa Bay Camaros
Finally got my new bracket and a proper drill bit to drill hole. Will attempt new install this weekend again
Sent from my Note 10+ 5G using Tapatalk
#7 |
Tampa Bay Camaros
Could not wait and just did it this afternoon. Came out awesome!
Had to cut a bit of the grille off, but its in between the backplate and the bracket so nothing shows.
#8 |
![]() Drives: 2019 1SS M6 Join Date: Feb 2020
Looks great !!
#9 |
Tampa Bay Camaros
#10 |
I just purchased a 2017 with the illuminated bowtie. Mine looks to have water damage inside the clear plastic. Anyone else have this problem ? Also it doesn't light up very bright, not sure if the water damage is blocking the light somewhat or maybe a wiring issue. I also noticed the bowtie isn't secure it wiggles a little back and forth. Not enough that I'm concerned its going to fall off but wonder if something wasn't installed right from the beginning. I know it was dealer installed. My 3yr bumper to bumper is over but I do have an active 3month/5,000km CPO warranty on the car I'd think any problems with this would be covered ? Just hate taking my car into the dealer for anything though.
50th Anniversary, 2SS, Build#5771, A8, MRC, NPP, NAV, Sunroof, GM Performance CAI, Trifecta Tuned, GM splash guards, Black illuminated bowtie, GM smoked tail lights & third brake light, GM Fifty floor mats, Strut tower brace, JWM side markers, 20% window tint, Sto N Sho front license plate bracket
#11 |
![]() ![]() ![]() ![]() ![]() Drives: 08 Tiburon GS, 2018 Camaro 2.0T Join Date: Sep 2017
The fact that the bowtie is dim is normal, many threads on here are mentioning it.
But the condensation inside doesn't seem to be normal. I would assume that these should be sealed. I'd first call your dealer and ask them over the phone if it is normal and if your warranty would cover it.
2018 Camaro LS | 6 spd | 2.0L turbo | Nightfall Grey | RS package | Technology Package.
--------------------- Order WDGHKX 1100 - 5/08/2018 | 3800 - 6/18/2018 2000 - 5/09/2018 | 4200 - 6/21/2018 3000 - 5/28/2018 | 5000 - 6/27/2018 6000 - 6/29/2018 |
#12 |
A small wiggling is normal, too, unfortunately plastic retainer clip tolerances are pretty wide on this one.
#13 |
Tampa Bay Camaros
I agree that it is dim. Hard to see during the day for sure. However, the 2020, where the harness plugs into the headlight harness, seems to be a tad brighter than the one in my 2018.
Here is a pic from last night The moisture certainly seems odd though. My old 2017 had the LEDs go out in half the bowtie.
#14 |
![]() Drives: 2020 Camaro SS Join Date: Jul 2020
What bracket did you need to buy? I'm trying to do this to my wife's 2020 SS and was about to order the illuminated bowtie but saw your write up. Also can you elaborate on what exactly you needed to trim to make it work. I'd really appreciate it.
Thank you!
