![]() Drives: '20 ZL1 M6 Join Date: Apr 2017
tires
I'm gonna need tires shortly and I'm considering going to PS4S's. I had them on my '17 SS 1LE and they were very good.
For the OEM sizes, the section width of the Michelins is exactly the same as the SC3's, but the tread with is a little less. Will one size wider tires, i.e. 295/30 front, 315/30 rear, fit with no issues? Thanks.
Mal
Ft. Lauderdale, FL '20 Camaro ZL1 M6 '22 Kawasaki ZX-14R |
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: E92 BMW M3 Join Date: Oct 2012
Edit: Michelin site says it fits the Camaro ZL1 wheel, and has a range of 10.5-11.5 inch wheels for their 315/30/20. Do it!
J-Rod Built and Matt@FSP Tuned |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
There's not a thing to be gained or lost in the miniscule width difference between the two that you'd need to look at a 295 or 315. THe 315/30 should fit without a problem it's the 35 series sidewall where you can get in to a rub and or need a spacer; 305/35
Thanks guys. Yes, there isn't a big difference in tread width but it was noticeable on my SS 1LE when I switched from the SC3's.
Mal
These sizes will work. (I haven't personally checked 295/30 fronts on a ZL1, but don't recall any warning posts or issues from others either.)
You probably want to relocate the main body wiring harness on the driver side rear to be safe, here's how: https://www.camaro6.com/forums/showthread.php?t=485975 (you'll probably find other, newer threads as well).
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
I would just go with the stock sizes front and rear and call it done! The wider the rubber the more money they cost.
#7 |
Limitless Imagination
Drives: 2018 ZL1 & 2022 Hayabusa Join Date: Dec 2016
I've ran SCY3, PS4 and currently on Hankook Evo2. This is the stickiness order best to worse. I daily my ZL1 and live in Louisiana so I frequently drive in the rain (maybe similar to FL?) and while the Hankook's are not the stickiest in this group, they do the best in the rain in my opinion. They also have higher treadwear and cheaper as a bonus.
On the PS4s, I ran 315s out back. Ever since they were mounted, I regretted going up a size. The sidewall budges just enough more that to me it looks funny compared to the 305 sidewall. Did or will anyone notice this? Not at all, but bugged me.
2018 Camaro ZL1 - Black
- OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof - Lightly Tinted GM Dark Tails, DD Side Markers, Morimoto 5000k, 100% LED - RotoFab Dry, Forgestar CF5V (ZLE Spec), Eibach Pro, AeroForce Interceptor, GT4 Tow Hook - Carbon Fiber (Satin): Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin 2022 Suzuki Hayabusa - Brilliant White Pearl & Shocker Yellow Wheels - +4 Arm, 240 OEM Wheel, Brock's CT (Ti) Exhaust, 1.25" drop, etc... |
#8 |
![]() ![]() ![]() Drives: 2019 zl1 6 speed Join Date: Jul 2017
I had ps4s on my old ss, had around 490 whp, and I could not get traction in first, or second below 40. I just got a zl1 and bought brand new factory tires. I know they are only a little bit bigger than my last ones but man, they hold all the power so far, a little spinning from 1-2 on a no lift shift. Not gonna lie, I'm pretty impressed with the tires so far. Not the longest tread life and are a little noisy, but I don't mind giving that up for more grip. Tried a 40 roll yesterday in 1st and it dead hooked. Am I the only person that feels this way? I have yet to try 0-60 tomes with them yet tho
#9 |
![]() Drives: 18' A10 ZL1 , 18' F150, 04' MSM Join Date: May 2018
It's hard to beat the OEM tire for the street if you don't care about wet performance. I tried the P4S but definitely prefer the SC3's.
#10 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 CT4-V Blackwing Join Date: Sep 2013
2013 Camaro SS 1LE - Black - M6 - Sold 2016 Camaro SS - Mosaic Black - A8 - Sold 2017 C7 Stingray - M7 Coupe - Sold 2019 C7 Grand Sport M7 Vert - Sold 2021 Camaro ZL1 - Black - A10 - Sold 2019 Tesla Model 3 2022 CT4-V Blackwing - M6 |
#11 |
![]() ![]() Drives: Chevrolet Camaro ZL1 1LE Join Date: Oct 2021
Where are you finding SC3 for $1,200 a set? Enlighten me.
#12 | |
#13 | |
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
#14 |
I just paid $1398 for a set. I need to find the deals you're talking about!
