![]() ![]() ![]() ![]() Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
Strut Bracing in CT4/CT5-V Blackwing
I've read many times here that the ZL1 doesn't benefit in any way from an additional strut tower brace, which is reason why Chevy didn't include one. Members here are adamant about this, saying there is zero reason to add a $300 brace for track use.
If that's true why did GM put additional strut tower bracing in the state of the art Alpha 2 (evolved Alpha) chassis for the new track focused CT4/CT5-V Blackwings? You could safely assume the Alpha 2 is an improved version of the great Camaro Alpha chassis in the ZL1. Per the pictures below, the CT5-V BW has a stout looking standard strut brace and the CT4-V BW has more complex trick looking race car bracing connecting firewall-to-tower-to-frontmost chassis points. Based on this, seems like the Alpha chassis does benefit from additional strut tower bracing. |
![]() Drives: '22 Summit White ZL1 A10 Join Date: Aug 2019
@SFV1LE you realize you have caused MANY heads to explode.....lol
2022 ZL1 Summit White A10
2020 GT350 Heritage Edition-Chassis L0350 2019 ZL1 Summit White M6 2018 Hellcat White Knuckle M6 2016 Hellcat GoMango A8 2002 Dodge Viper Viper Red 2002 Corvette Z06 Millennium Yellow 1998 Dodge Viper Viper Silver Metallic |
![]() ![]() ![]() ![]() Drives: 2008 Pontiac G8 GT, Shelby GT500 Join Date: Mar 2011
Cadillac engineers must have seen an improvement in their testing.
![]() ![]() ![]() ![]() Drives: 2018 Camaro ZL1 Join Date: Aug 2018
I believe GM engineers themselves said that during testing for the Camaro that they saw very marginal improvement in stability with a strut.
Here's Al O's answer: https://www.camaro6.com/forums/showthread.php?t=517935 Maybe someone should ask the head of Cadillac why they needed a strut brace when the Camaro didn't. |
#5 | |
#6 | |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
#7 |
![]() ![]() ![]() ![]() ![]() Drives: 2023 CT5 Blackwing, 2025 C8 Z07 Join Date: Sep 2016
The premise of this post is false. The question always has been does Camaro benefit from an additional strut tower brace. All Camaro's already have front bracing installed.
Blackwing isn't a Camaro. If in the course of tuning the new chassis and MRC4 they discovered a strut tower brace helped the Blackwing, that doesn't have anything to do with Camaro.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 2025 Hysteria Purple C8 Z07 |
#8 | |
And both of those have shorter wheel bases than the Blackwing. Well, maybe not the CT4 but the CT5 for sure. It comes down to it you want it, get one. Buy the only way we would know if it improves anything is by letting one of the track rats try it out and if it improves any lap time or corner stability. Which Al O said the Camaro platform is good in the way they designed it to handle. Plus, if GM really wanted to add a strut brace then why didn't they add one in the 1LE package? Because the platform design is that good without it. |
#9 |
I didn't realize we had added Cadillac to the Camaro Menu. Must have missed that.
#10 |
![]() Drives: Garnet Red / ZL1 1LE Join Date: Apr 2016
With the ZL1/1LE, engineers did test a strut brace and found little to a marginal benefit to handling at the cost of adding mass at the front. Essentially - the unanimous answer was it was unnecessary.
Keep in mind - the ZL1/1LE is only at 3863lbs (6 speed) vs CT5V Blackwing at 4,123 lbs (6 speed)
#SAVETHEMANUALS
#11 |
![]() ![]() ![]() ![]() Drives: 2020 ZL1 1LE Join Date: Sep 2012
Did anyone ever try the CT5-V Blackwing brace on the ZL1?
#12 | |
![]() Drives: 2019 ZL1 1LE Join Date: Feb 2017
Old: 2017 SS 1LE
Old: 2017 ZL1 Current: 2019 ZL1 1LE |
#13 |
![]() ![]() ![]() Drives: 2018 ZL-1 Join Date: Jan 2018
Why add a front strut tower brace, when the rear control arms are so flexy? There is more stiffness available by upgrading them first. They are the low hanging fruit.
However, GM provided a channel in the hood of the Camaro to accommodate a strut tower brace for a reason: Either to sell an aftermarket accessory, or improve the chassis stiffness. |
#14 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Hot Red ZL1 Join Date: Nov 2010
