Old 06-29-2022, 02:31 PM   #1
MartinLe
MartinLe's Avatar
Drives: 2017 Chevrolet Camaro ZL1 M6
Tire Pressure Question
I understand that we want to run our rear Nitto R2's at 27 - 29 psi hot for street use. For me, that means I need to have my cold tire pressure at 24 - 26 psi. Of course, that triggers the TPMS light on my dash. After the day warms up, my tire pressure goes up to 27psi, but the light stays on. So far, I have not noticed any downside to this. I have made a few hard acceleration passes and all seems fine. Am I missing anything?
JRE Terminator Rough Idle Cam
Magnuson 2650 - 15% lower, 90mm upper
FIC+30%
DSX Flex fuel/Low side
NW 103mm TB/Roto-Fab CAI
Monster S Series
Elite E2-X
2" TSP LT's
BMR:BK063, BK060,TCA061, UTCA060, UTCA063
Weld Beadlocks/17" NT5R2
MartinLe is offline   Reply With Quote
Old 06-29-2022, 07:38 PM   #2
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
There is not performance reduction tied to low pressure warning. I've got the same tires and shoot for 27-28 cold on the street vs. dealing with the warning light.
Old 06-29-2022, 10:59 PM   #3
grampa_ss
grampa_ss's Avatar
Originally Posted by LiqTenExp View Post
There is performance reduction tied to low pressure warning. I've got the same tires and shoot for 27-28 cold on the street vs. dealing with the warning light.
I don't think this is true. Low pressure warning is ok and won't pull any power. However, a TPMS error will pull power.
Old 06-30-2022, 06:08 AM   #4
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
I forgot a critical word "not". I corrected what I said above
I run with low pressure in the back all the time and it has no impact to the car, no TqMgtAdv impact or anything.
Old 06-30-2022, 11:54 AM   #5
MartinLe
MartinLe's Avatar
Thanks, guys. Just to clarify: A TPMS error is different than a low pressure warning. I have the low pressure warning showing on the bottom right hand of the speedometer.
FIC+30%
Monster S Series
Elite E2-X
2" TSP LT's
Old 06-30-2022, 12:06 PM   #6
clg82
Drives: 2020 Camaro ZL1
I'm confused, I have no TPMS sensors in my BCForged tires and i'm not seeing any power being pulled.
Old 06-30-2022, 12:10 PM   #7
grampa_ss
grampa_ss's Avatar
Correct
Old 06-30-2022, 12:12 PM   #8
grampa_ss
grampa_ss's Avatar
This has been discussed on here and this was the result. You can have 4 sensors or zero sensors and all is ok. You cannot have just 2. You will eventually get a TPMS error.
Old 06-30-2022, 12:17 PM   #9
MartinLe
MartinLe's Avatar
Correct
Thank you.
FIC+30%
Monster S Series
Elite E2-X
2" TSP LT's
Old 07-01-2022, 06:34 PM   #10
StanZL1
StanZL1's Avatar
Drives: 2022 Camaro ZL1
I’ve run stock Supercar3’s at 30-32psi hot on extra rims for 4 years without TPMS; and Nitto 555R2 with TPMS as my street tri-season at 32 psi cold and as my wet-track at 32psi hot. Great experience with both. And never ever pulled power with TPMS error.
StanZL1 is offline   Reply With Quote
