![]() Drives: 18 zl1 garnet red Join Date: Aug 2021
zl1 elsd drag racing performance calibration
Chevrolet advertises this on their performance page and it says :
Continuous drag strip development combined with the pursuit of perfection have pushed our Camaro engineers to develop an eLSD calibration that enables more consistent burnout performance for improved drag strip launches. This exclusive calibration doubles the differential coupling torque during burnout and drag launch scenarios by increasing the pressure applied to the clutch pack in order to prevent relative slip between the clutch plates. As a result, burnouts warm both tires evenly which is essential for a straight launch. Dealer install only. Will not void the New Vehicle Limited Warranty. Note: This calibration is for drag racing purposes only. The eLSD Drag Performance Calibration will only be enabled when the vehicle is in Traction Control System Off. Driving vehicle on public roads with traction control system and electronic stability control system disabled is dangerous and not recommended for any operator. has anyone done this calibration?
IG - @zl1_will
2022 zl1 740hp / 730tq stolen ![]() 2018 zl1 Maggie - 2" headers - flex fuel - lowside fuel ssytem - +30 injectors - cordes ice tank - spl rear linkage arms |
![]() ![]() ![]() ![]() Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
Did you search the forum? There have been recent threads discussing this at length.
![]() ![]() ![]() ![]() Drives: 2018 Camaro ZL1 Join Date: Aug 2018
Basically it's isn't worth the money. Use your money for a real performance upgrade.
![]() Drives: 2020 Rally Green ZL1-1LE Join Date: May 2020
For Zl1-1LE owners who see this, this is not available for our cars. I took my 2020 to the dealership and they said it wouldnt work with my VIN.
![]() Drives: 2022 camaro 2ss 1LE Join Date: Dec 2021
It was said the dealer charges $350 to install either tune, the autox one or the drag one. IMO it should already come loaded in the car.
![]() Drives: 2003 Monte Carlo SS SLP, 2022 ZL1 Join Date: Aug 2021
#7 |
The autox one is for the ss 1le, the drag one is for the zl1
https://www.streetmusclemag.com/news...d-calibration/
#8 | |
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
#9 |
Has to be a chevy performace specific dealer. Theres a link in that new doc up there you can click on and it will locate one for you. The closest one to me is like an hours drive.
#10 | |
![]() Drives: 2020 Camaro SS 1LE Join Date: Apr 2022
#11 |
It makes you able to enter and exit corners faster. So your lap times are better.
#12 |
![]() Drives: 2017 Chevrolet Camaro ZL1 Join Date: Jul 2018
I did it when it first came out but didn’t notice anything different. Part of the reason could be that it requires stability and traction control to be off and I always leave stability control on. My logic is that it the car breaks lose enough for it to kick in, the pass is already shot so might as well have a little extra safety.
2017 ZL1 - PB 7.85 @ 175 MPH @ 3682 lbs @ 1313 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned |
#13 |
All my passes have been with all nannies off. The car needs little if any rear bias for what I'm doing these days.
2020 ZL1LE A10.
#14 |
Definitely doesn’t hurt but it’s a huge misconception that it’s required for this platform. I’ve done 1.20 60’s with it on.
