![]() Drives: 2021 camaro lt1 Join Date: Dec 2021
Lt2 intake manifold
Hey everyone. So I installed the lt2 intake manifold on my Camaro today. When I went to connect the maf extension. On one side it clicked in right away. The other side it seems no matter how hard I tried to get it to click it just wouldn’t. Was wondering if anyone else had a similar issue and what did you do to fix it? I just pushed it down as far as I could and wrapped it with electrical tape. No check engine light came on so I believe it’s down enough to get a signal and it’s drives the same as the original intake manifold, but it still bothers me it not being connected all the way. Below is the extension I got which seems to be the one everyone recommends to get. Got it off of Amazon.
ICT Billet Wire Extension 24" LS Gen 4 MAP Manifold Absolute Pressure Sensor Connector LS3 OEM tooling, OEM Delphi (connector, lock, seals, and terminals WEMAP40-24 |
![]() ![]() ![]() ![]() ![]() Drives: 20’ Chevrolet Camaro 2SS 1LE Join Date: Jan 2009
Yes, when I was doing my homie’s LT2 intake, his ITC billet wire extension was not clicking at all. I had no problem on mine, must of been a bad batch. I had to file down the little tab that locks in. I don’t have a picture to show you, but you don’t have to file down too much, only like less than 1/16th of an inch.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: like an old lady Join Date: Jun 2012
i used the mid michigan harness, no issues.
![]() Drives: 2021 1SS 1LE Join Date: Nov 2020
I had the same issue with my GPI extension. I ran a zip tie around the entire connector and though the tab. No issues, but for sure not ideal. I called GPI and they said they had never heard of this issue and didn’t have a solution….
Ken |
![]() Drives: 2010 camaro Join Date: Dec 2017
it will click in... I thought at first they send me a defective one, but it will go in will enough force. You will hear in audible click.
![]() Drives: 2017 Camaro SS 1LE Join Date: Sep 2023
#7 | |
![]() ![]() ![]() ![]() ![]() Drives: 2017 2ss 6mt Join Date: Mar 2024
Ive got to where i put dielectric grease on most every connector i take apart. It will lube the seal and let them slide together really smoothly. I don't know if thats the case with yours but it wouldn't hurt to try. |
#8 | |
#9 |
Ive really been thinking about this as my next mod. But i wouldn't use a adapter harness. I would either refit the intake for the sensor to be on the normal side or lengthen the harness to fit the intake. More connections are more placed for failure to me.
#10 |
It's an extension.
| Tags |
| lt2, lt2 intake installation, lt2 intake manifold, maf sensor harness |
