Old 02-11-2022, 12:25 PM   #1
BanOne
Drives: 1977 Pontiac Trans Am
Manual Transmission Fluid Change
Thinking of doing this change after about 4K miles and 6 track days. I have never done it so do not think it would be a bad idea to do. I know that even in the manual transmission it uses synthetic LV ATF HP (the blue label). Not sure what the difference is between the blue label and black label. I also am looking for what the red thread seal is used on the drain and fill plugs?
Thanks for the info
BanOne is offline   Reply With Quote
Old 02-11-2022, 01:06 PM   #2
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
i didnt even realize mine had any tranny fluid till about 4 years in lol just did a flush and refill at dealer did notice the shifter seemed to feel better but thats about it but i just used oem gm fluid
Old 02-11-2022, 03:40 PM   #3
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
I used Royal Purple Synchromax, I didn’t use the drain I used the temp sensor as the drain. Pretty easy job probably 40 minutes in all. A little high temp thread seal back on the temp sensor. I definitely feel like the Royal Purple improved the smoothness in shifting especially when it’s cold.
pauly1119 is offline   Reply With Quote
Old 02-11-2022, 05:22 PM   #4
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
drain & refill... sometimes the hardest part is refilling as the access is tight and you need a hand pump to refill
Old 02-11-2022, 09:25 PM   #5
Wuiquen
Wuiquen's Avatar
Drives: 2018 Hot Red ZL1
Yep. I used Amsoil ATF. Hardest part is making sure you have the right level. It is no the traditional full until it drips out.
I like Amsoil because it comes in squeezable packages. Super easy to refill
Old 02-11-2022, 09:26 PM   #6
MatthewAMEL
MatthewAMEL's Avatar
Hand pump?! We don't need no stinkin' hand pump!
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
2025 Hysteria Purple
C8 Z07
Old 02-12-2022, 06:38 AM   #7
SteveV
SteveV's Avatar
Drives: 2018 ZL1 Camaro 6M Red Hot
I also put RP Synchromax in mine at the 6k mark. Made a noticeable difference. With the stock fluid, when the temp outside was below 50, the first to second gear shift would be notchy and clunky. Since switching to synchromax, that notchy-ness is gone and it shifts noticeably smoother.
I have just over 22k now on my ZL1 and it still shifts great.
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
SteveV is offline   Reply With Quote
Old 02-12-2022, 06:52 AM   #8
6spdhyperblue
Drives: 2SS 1LE
RP synchromax is the only product from them I use but think it’s a good improvemment. It’s thicker than the oe oil so may give some extra protection as well
Old 02-12-2022, 08:23 AM   #9
BanOne
Transmission Fluid
Thanks for the responses. I had not heard the fil level is different, I have a hand pump so I can do that, but I am wondering about the thread sealer, is it anything special or whatever I can find at Autozone?
Thanks
Old 02-12-2022, 08:51 AM   #10
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
Thanks
Its just 1/8 inch below the fill level. I filled it to the fill level and then just sucked a little back out. Its pretty hard to actually see in there. Car should be level too to be accurate. I tried to make a little tool to see the level but I thought it would be just as easy to remove just a little bit. I used a little 30CC syringe to pull just a little back out.
Old 02-12-2022, 09:55 AM   #11
BanOne
Thanks, you just get the thread seal at Autozone, permetex white stuff? I just noticed it was red and wondered if there was anything special about it.
Old 02-12-2022, 10:48 AM   #12
6spdhyperblue
Drives: 2SS 1LE
Isn’t the red the oil resistant one?
Old 02-12-2022, 12:24 PM   #13
getchapull
TEXIT
getchapull's Avatar
Drives: 2019 ZL1 M6
Don't worry about the 1/8th inch below fill line stuff. I was curious and emailed Tremec, here is the correspondence below. Filled with the RP synchromax along with all others RP fluids in my vehicles. My vehicles love the Synerlec additives!
Hello and thank you for contacting Tremec.
Your trans will take approx 3.84 liters you’ll need to buy 4qts you will use just under 4. Add fluid until it comes out of the side plug and then cap it.
Thanks,
Doug Kovach
Customer Service Representative
__________________________________________________ _____
TREMEC
TORQUE TRANSFER SOLUTIONS
46643 Ryan Court
Novi, MI 48377
Phone:. +1 (248) 859-6321
Doug.kovach@tremec.com
getchapull is offline   Reply With Quote
Old 02-12-2022, 12:47 PM   #14
BanOne
Thanks,
Doug Kovach
TREMEC
46643 Ryan Court
Novi, MI 48377
