Old 02-03-2022, 12:46 PM   #1
ChadSZL1
Red Bull
ChadSZL1's Avatar
Drives: 2017 Chevy ZL1
Exclamation WHAT LIFTERS TO USE WITH CAM
What lifters do you all suggest with my cam install?
ChadSZL1 is offline   Reply With Quote
Old 02-03-2022, 01:32 PM   #2
KamZL1
KamZL1's Avatar
Drives: Z06
I think most of the high power guys use johnson
KamZL1 is offline   Reply With Quote
Old 02-03-2022, 01:36 PM   #3
Puddin
Johnson or the Cadillac racing lifters.
Old 02-03-2022, 01:58 PM   #4
swisstyphoon
Former GM Technician
swisstyphoon's Avatar
Drives: 2018 ZL1 A10, 06 Silverado Duramax
I'm happy with the Johnson 2110R
Which cam are you using? Specs?
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, DSX dual intank pump, Lingenfelter high flow check valve, Motion Raceworks Flex Fuel adapter, LPE Big Bore Hpfp, XDI 30% Injectors, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can.
2006 Silverado Duramax Diesel
MPI Compound Turbo
40% over Injectors
Efi Live DSP5 Tuning
Follow me on Instagram: SwissZL1
swisstyphoon is offline   Reply With Quote
Old 02-03-2022, 02:22 PM   #5
JSH
JSH's Avatar
Drives: '20 ZLE
The manufacturer or specs?
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 02-03-2022, 02:56 PM   #6
Smokin19
Drives: 19' ZL1 A10, w/pdr
Johnson is going in my build.
Smokin19 is offline   Reply With Quote
Old 02-03-2022, 10:30 PM   #7
ChadSZL1
Red Bull
ChadSZL1's Avatar
I just got the stage 2 BTR 38% fuel lobe….. looking at the gm performance lifters. (Caddy)
Old 02-04-2022, 08:02 PM   #8
Revalot
Drives: ZL1/1LE parts added
Location: Somewhere around Texas pines tress and smooth asphalt
Ok
Revalot is offline   Reply With Quote
Old 02-04-2022, 08:25 PM   #9
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Johnson 2110R here
Old 02-06-2022, 09:27 AM   #10
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Johnson 2110r lifters are what they use in the Copo Camaros that turn 8500rpm. Probably the best drop-in option there is for a hydraulic roller cam setup on stock rocker arms. A more affordable solution is the Morel 7717. I have used those in a LS build turning 7200rpm with no issues.
True LS7 lifters were designed around a engine that had a pretty light valvetrain and very mild cam lobes. If using Titanium intake valves, beehive or conical springs, with soft cam lobes, you could likely make them work. Where guys run into issues is when they pair them with heavy dual springs, heavy valves, and aggressive lobe cam, then try to spin it to the moon.
Think of a valvetrain setup as a Orchestra.
Old 02-06-2022, 10:07 AM   #11
JSH
JSH's Avatar
Drives: '20 ZLE
I agree, which is another reason to have experienced shops do the work, because they have sorted out the components that work best together for each build. HPE is so secretive about its intellectual property that they won't even tell the customer the components or specs they used.
2020 ZL1LE A10.
