Old 01-16-2022, 01:44 PM   #1
ChadSZL1
Red Bull
ChadSZL1's Avatar
Drives: 2017 Chevy ZL1
Exclamation Replace timing chain guide?
When replacing the oil pump is anyone changing the timing chain guide? I have seen where people say the stock guide can cause issues. If so what brand is everyone using?
ChadSZL1 is offline   Reply With Quote
Old 01-16-2022, 01:59 PM   #2
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
Chain tensioner/guide failures were common with the LS engines. I haven't heard of the same issue on the LT engines, although the tensioner is very similar between the two. For the LS motors, most folks went with the older style LS2 "bowtie", it's a guide not a tensioner.
I've seen one for the LT engines from LME, not sure if it is needed like it was on the later LS engines
It would be interesting to hear if folks have seen them broken when doing a cam or oil pump swap.
Old 01-16-2022, 02:30 PM   #3
ChadSZL1
Red Bull
ChadSZL1's Avatar
I agree!! I hope to hear from some people who did the cam change/oil pump if they changed it out?
Old 01-16-2022, 05:19 PM   #4
Mark R
Drives: 2018 ZL-1
My 2018 had the oil pump changed in November, and I am sure the tech would have alerted me to a cam chain guide issue if he saw one. He did not.
Old 01-17-2022, 03:33 PM   #5
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
That is not the guide that was listed as an issue.
https://gm-techlink.com/?p=12041
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 01-17-2022, 07:47 PM   #6
ChadSZL1
Red Bull
ChadSZL1's Avatar
So would it be worth changing?
Old 01-18-2022, 09:57 AM   #7
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
Chad, are you changing the timing chain? ie upgrade to CR5.
my thoughts: if running the OE chain, keep the OE tensioner. if changing the chain, go with the anti-slap style chain guide. I have no factual data to support these thoughts........ it's only $$
Old 01-18-2022, 10:21 AM   #8
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I read there was a defect in the chain guide on some models. This article shows up to 2106 but I seen another video(I can't find now lol) where it happened on a 17-18 ZL1.
https://www.autoserviceprofessional....r-chevy-camaro
Old 01-18-2022, 12:44 PM   #9
ChadSZL1
Red Bull
ChadSZL1's Avatar
Yes I am going to upgrade the timing chain also. But wanted to know if changing the guide would also be a good preventative measure.
Old 01-19-2022, 08:27 AM   #10
nighttowl
nighttowl's Avatar
I would if I were you. if you're already in there, might as well do it especially since GM technical bullitin says there are issues on some vehicles up to 2019.
Old 01-19-2022, 08:47 AM   #11
KingLT1
KingLT1's Avatar
YES
