![]() Drives: 2018 1SS 1LE & 1973 Datsun 240Z Join Date: Sep 2015
CTS4V Blackwing Rear Brake Scoops
I debated where to post this, but this is likely only something that only someone who tracks their car would care about...
I was watching the video review linked below of the CTS4V Blackwing and at the 7:59 mark, it shows the rear suspension with what appear to be scoops for the rear brakes. Given that I believe the suspension is relatively unchanged from the first gen Alpha platform, I wonder if these would fit the Camaro? Granted, overheating rear brakes isn't a big problem with the Camaro, but extra cooling never hurts. Just planting the seed for now. I'll dig into it a bit further as I have time, unless someone else beats me to it. So far, I've learned they only come on cars without the carbon-ceramic rotors. Nigel |
@zle_blackwing
Drives: 2018 ZL1 1LE Join Date: Mar 2017
I have a CT4-V Blackwing (which is not available with carbon ceramic brakes which are an option on the CT5-V Blackwing) as well as my ZLE. I can take some pics of them, scan the installation sheet and give any dimensions etc. anyone would like. They come in the trunk. They are not installed on the car from the factory.
#3 | |
![]() Nigel |
![]() Drives: 14 Camaro SS 1LE Join Date: Feb 2019
Here are the PN's that I could find. The rears appear to use M5 screws. Don't think the Camaro has the tapped holes for them
GM 84946132 - Rear Right GM 84946131 - Rear Left GM 11548166 - Rear Bolts (Qty 6 needed) GM 84965151 - Rear Lower Trailing Arm |
![]() Drives: 2019 SS 1LE Join Date: Jun 2018
is that a stamped arm? Could be as easy as a drill and rivnut to get the job done.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
There are also larger scoops at the front. They are different than the big non-SS 1LE scoops.
"KEEP THE FAITH"-Fbodfather |
#7 |
#8 | ||
Nigel |
#9 | |
Video of the CT5 front brake scoops. Both the CT4 and CT5 front scoops look different than each other and they both appear different than anything available on a Camaro
#10 | ||
The fronts do appear to closer in size to the Camaro track deflectors, but much more heavily sculpted. Might be worth picking up a set for side by side comparison. Nigel |
#11 | |
@zle_blackwing
#12 |
![]() ![]() ![]() Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
It looks like the CT4-V Blackwing's rear calipers (pictured below) are a little over 135° away from the Camaro's placement (with the parking brake caliper in the same location as the Camaro's regular caliper) and the CT5-V Blackwing's are a little over 45° away so idk if the airflow will end up in the right place on the Camaro but some temperature paint or stickers on the calipers with a before/after test could answer that question.
#13 | ||
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
I can't believe he is jacking the car from the aluminum cradle.
#14 | |
Geoff
Drives: 2022 SS 1LE Join Date: May 2013
thx in advance
