Old 11-24-2021, 03:32 PM   #1
GA_ZL1
GA_ZL1
GA_ZL1's Avatar
Drives: 2023 ZL1 1LE
2018 ZL1 1LE front under tray part # and replacement
Updated post: Am I correct in assuming the the front splash tray for my 2018 ZL1 1LE is part # 84084634, as AZ_1LE noted? I have circled the part I'm referring to in GREEN. Also, does anyone know the part numbers for the guards circled in RED are? I may have to replace them, too. I think they are separate (2 different) parts.
Note: The photo I used is from Hypermotive web site and also shows their scuff guards https://www.hypermotive.com/protekt-...170/#gallery-4
My original post: I damaged the front under tray on my ZL1 1LE. I'm referring to the plastic piece that fits behind the front splitter and covers up oil cooler radiator and other parts up to and past the front wheels and axels. Does anyone know the part # or where I can find a diagram of GM front undercarriage parts for our ZL1 1LE cars? Anyone every replaced one of these? It looks to be just a simple bolt on. TIA!
GA_ZL1 is offline   Reply With Quote
Old 11-24-2021, 03:38 PM   #2
AZ_1LE
Drives: 2019 ZL1 1LE
This? https://www.gmpartsdirect.com/v-2019...splash-shields
Old: 2017 SS 1LE
Old: 2017 ZL1
Current: 2019 ZL1 1LE
AZ_1LE is offline   Reply With Quote
Old 11-24-2021, 03:44 PM   #3
GA_ZL1
GA_ZL1
GA_ZL1's Avatar
Thanks AZ_1LE!!! You wouldn't also know the part number for the 1LE plastic shields that are behind the under tray? There is one on each side. It looks like they protect the floor pan. I may have damaged one or both of those shields, too.
Old 11-25-2021, 06:56 AM   #4
Firecaptain
Firecaptain's Avatar
Drives: '22 Summit White ZL1 A10
Well if you damaged all of those......you must surely need the deflector too no?
https://www.gmmidatlanticparts.com/o...ector-84244390
Firecaptain is offline   Reply With Quote
Old 11-25-2021, 10:33 AM   #5
GA_ZL1
GA_ZL1
GA_ZL1's Avatar
Thanks! Actually, it is not damaged. Must have folded under. BUT, since I'm ordering the under tray, I might as well replace it!
Old 11-26-2021, 11:45 AM   #6
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
here you go
# 1: 84084634
# 17: 23343551
# 5: 23343550
Old 11-26-2021, 12:19 PM   #7
GA_ZL1
GA_ZL1
GA_ZL1's Avatar
Thank you, Geoff! Just what I needed. Hope you had a nice Thanksgiving.
Do you by any chance have a link to the exploded diagram you attached? I am having a hard time finding the proper schematics of undercarriage parts on the various GM parts websites. TIA
Old 11-27-2021, 10:08 AM   #8
Trackpack
Trackpack's Avatar
Drives: 1LE
There appears to be a cooling upgrade related to the tray circled in red. These vents add cooling to the power steering. The owner of the ZL1 1LE I took the pictures of mentioned they were a factory GM part for another version of the Camaro (maybe an SS 1LE). Any idea what part number these are?
Trackpack is offline   Reply With Quote
Old 11-27-2021, 03:19 PM   #9
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
We did, thx
Sorry, I can't provide a link. I have limited access to some GM dealership diagrams
84669205, this kit was included with the ZLE starting in 2019 or 2020
Some pictures here: https://www.camaro6.com/forums/showp...7&postcount=41
Attached is the service bulletin in regards to steering overheating
Old 11-27-2021, 05:01 PM   #10
Trackpack
Trackpack's Avatar
Drives: 1LE
I appreciate you Geoff!
Old 11-27-2021, 05:38 PM   #11
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
You're welcome sir
Old 12-01-2021, 11:57 PM   #12
Sorange
Sorange's Avatar
Drives: 2018 ZL1 1LE
I have been meaning to upgrade those pieces circled in red on my 2018 for z while now and still haven't done it. Maybe a good winter project!
Sorange is offline   Reply With Quote
Old 12-02-2021, 05:42 AM   #13
khcoaching
khcoaching's Avatar
Drives: 2021 1SS 1LE
I appreciate these threads, even though I have a standard SS.....Can you retrofit the ZLE under pan on the SS 1LE?
Ken
khcoaching is offline   Reply With Quote
Old 02-23-2025, 11:58 AM   #14
LancevanceZLE
Reviving an old thread, but does anyone know the part numbers for those aero deflectors shown pn the side in the picture?
LancevanceZLE is offline   Reply With Quote
